Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > '08-'10 Upgrades and Aftermarket
'08-'10 Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 11-08-2009, 01:53 PM   #1 (permalink)
RLBA's Avatar
Heated Seat Bypass Wiring
Has anyone bypassed the heated seat switch and wired their heated seat so it can come on when the remote start system is used?
Randy
2009 F-450, 6.4, auto, CC, 4x4, chrome pkg, Lariat ultimate pkg, Pueblo Gold w/Camel leather, navigation, moonroof, loaded, Reese 24K signature series hitch, Retrax bed cover, Transfer Flow 60 gallon replacement tank, MBRP 4" dual exhaust, 4" DPF/CAT delete pipe, 4" downpipe, Banks Techni-cooler, RCD CAC tube, Firestone Ride-Rite air bags, AFE stage 2 cold air intake with torque tube, Spartan Diesel Tecnologies Phalanx tuner with Dash Daq XL
2008 KZ 41' CKS Escalade Sportster Toyhauler, full body paint, cherry wood cabinets, triple slides, triple AC's w/heat pumps, 7kw Onan Generator, king bed, dual pane windows, Corian counters, central vacuum, fuel station, roll out tray, slide toppers, convection microwave, dual electric garage beds, fireplace, Morryde suspension, disc brakes with never lube axles, power awning w/wind sensor, Sony Xplod stereo, Satellite, Trail Air pin box
2007 Harley Davidson Screamin Eagle Road King, 110 CI, 6 speed, Razor Red w/Gold Leaf Flames, Super Trapp mufflers, Screamin Eagle Race module, matching painted Dragonfly fairing, Klock Werks smoke windshield, Sirius Satellite, AM/FM/CD, 6x9's 12V plug, stereo hand controls, Legends air suspension, LED lighting, driving lights, Screamin Eagle tour pack
RLBA is offline
Old 11-09-2009, 10:32 PM   #2 (permalink)
I was actually wanting to wire either the 1 or 2 button to do this but could not find any documentation. Those buttons do nothing and I want to use them....
2008 F250 Powerstroke
FordMudder is offline
Old 11-10-2009, 05:59 PM   #3 (permalink)
F450Mikey's Avatar
You could wire it to an up fitter switch and leave the switch on. Then the heaters will fire up when the truck is started.
2008 F450 Dark Shadow Gray Lariat "Pick Up" Job 1
2006 Weekend Warrior FSC 2800
2005 Honda CRF 450R
F450Mikey is offline
Old 11-10-2009, 11:14 PM   #4 (permalink)
All my switches are taken. I want to use the number 2 button for my air horn as well.
Old 11-14-2009, 07:07 PM   #5 (permalink)
Here is what a kind poster on another forum worked up. I did it on mine. Works perfectly.
Pre-Heating Optional Heated Seats on Vehicles with Remote Start and Upfitter Switches
The optional 2008 Superduty Heated Seats operate on a resetting switch that can be activated only with the key in the ignition and by depressing the heated seat button on the dash (driver/passenger). If you don’t like sitting on cold seats, this can be a problem.
Remote Start:
For those with a remote start, upfitter switches, and heated seats, a quick hardwire alternative is present by utilizing one of the upfitter switches as a means of powering the heated seats in parallel to the dash mounted buttons (heated seat buttons remain functional)
Note: It has been reported that some remotes starters do not provide power to the upfitter switches. It is my experience dealer installed “Ford” remote starters do successfully power the upfitter switches (a must for this application to work). Verify power to the upfitter switch wiring before proceeding.
How it works once complete:
  • Select the Upfitter Switch wired to the heated seat and leave in the “on” position (up)
  • Remote start vehicle
  • Enjoy “warm” pre-heated seats upon arrival
Tools:
  • Multimeter
  • Wire Connectors
  • Approx. 20ft of wire (14 ga)
  • Wire Cutters
Approx. Install Time – 1 hr.
Getting Started:
Remove Trim Cover beneath the Steering Wheel
Locate Four (4) Upfitter Switch Wires
Switches Color Fuse
Aux 1 Yellow 30 Amp
Aux 2 Green/Brown 30 Amp
Aux 3 Violet/Green 10 Amp
Aux 4 Brown 15 Amp
For this application, select any of the upfitter switches.
Beneath the front of each of the driver and passenger seats resides the heated seat relay.
Installation:
  • Remove the door sill panel on the driver side – simply pull up along the length.
  • Remove the kick panel on the driver side (near the parking brake pedal) – pull out on panel (see picture)
  • Advance the driver seat to the full forward (front of vehicle) position (exposing the existing through-hole in the carpet)
  • Route new power wire through the hole in carpeting beneath seat toward the driver door until exposed at door sill (currently removed)
  • Route the wire through the existing cable tray beneath the door sill panel, and up through the dash to the upfitter switch wiring.
  • Terminate this wire to the desired upfitter switch using wire connector.
  • Return the driver seat to the full back position. Ensure adequate wire is provided for full seat travel front-to-back.
  • Note: The heated seat relay is a black plastic assembly located at the front of the respective driver and passenger seat. It is clipped to the metal frame bottom of the seat structure and can be pulled/slid from the retaining clip without fear of damage (though stubborn). There is no need to remove the relay portion of the assembly from the wiring.
  • Using a multimeter, check voltage and select the wire with (0 voltage) on the heated seat relay with the Ignition “on”, and heated seat selector “off “.
Verify your finding:
Toggle the corresponding heated seat switch on the dash to verify a state change from 0-volts to 12-volts on this wire when the heated seat switch is “on”. This is the wire to connect direct power from the upfitter switch. Connect upfitter switch power to this specific wire using a wire connector. Repeat for both seats (if desired).
Time Saver:
For 2008, the desired wire for my driver seat is ( Yellow / Blue ), and for my passenger seat
( Grey / Blue ). Check to verify this is correct for your application using the multimeter.
2009 - 250SD - Lariat - 4X4 - SB - SC - V10 - Auto - 4.30's - Royal Red/Black - Loaded.
taken is offline
Old 11-15-2009, 11:13 AM   #6 (permalink)
RLBA's Avatar
Thanks Taken for this post. It looks very thourough. I will try this once my remote start is installed this week.
Randy
RLBA is offline
Old 11-15-2009, 11:22 AM   #7 (permalink)
Glad to pass it along Randy. I actually had two switches open so I did mine separately for the driver and passenger side. I figured I could always jump it back to one if I needed the switch in the future.
taken is offline
