I need a shorter antenna - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 10-05-2009, 11:39 PM   #1 (permalink)
The good news.....my truck fits in my garage....barely.
The bad news....my antenna is about 2" taller than the garage door opening. It seems to be flexing enough that it isn't bending, etc. but I'd really rather not keep scraping the antenna end. One day it might catch. Anyway, does anyone have any leads on a good brand that has good reception and looks good. I would prefer a stock looking antenna if possible, just shorter, but still tuned to work properly. Oh yeah, this is for a 2010 F250.
Jerry
Jerry Miller is offline
Old 10-06-2009, 09:40 AM   #2 (permalink)
Antenna
I have shortened the antenna on my F250 to fit in the garage. It is actually pretty easy to do.
Remove the antenna. Put a piece of terry cloth over the ball at the top to protect it and use a pair of vise grips to pull the ball off. You may have to twist it to get it to pop off but it will pop off.
Cut off the few inches you need removed to clear the door jam.
Then you can put a drop of epoxy on the end of the antenna and tap the ball back on.
I barked up my ball slightly and just used a black Sharpie to hide the brass that showed through when I tapped the ball back on.
I have not noticed any loss of signal from shortening the antenna. I did have terrible reception when I tried using a 9 inch "stubby" rubber antenna though.
wbarrett56 is offline
Old 10-06-2009, 10:11 AM   #3 (permalink)
Thanks for the info. I think I'll do that. I was looking at the stubby antennas that are solid stainless steel but I think that might be too stout. Iff it did get bumped it might break my antenna base in the cowl. At least a shortened stock antenna will flex. I guess I can use a drop of Red Loctite to secure the ball back. That crap holds pretty well.
Thanks,
Jerry
Old 10-06-2009, 05:37 PM   #4 (permalink)
F450Mikey's Avatar
Check this out...
9-Inch Billet Antenna
2008 F450 Dark Shadow Gray Lariat "Pick Up" Job 1
2006 Weekend Warrior FSC 2800
2005 Honda CRF 450R
F450Mikey is offline
Old 10-08-2009, 02:35 PM   #5 (permalink)
One thing to be aware of that I learmed the hard way....
Salt-air and aluminum stubby antennas are a bad combination. I had one on my old F150 and after a few years I went to take it out and it was a corroded mess. Had to replace the antenna mount.
Went back to the factory style whip and that is when I found the trick to shortening it so it did not look shortened.
Bill
Old 10-08-2009, 03:43 PM   #6 (permalink)
Another thing I worry about with the stiff shorty antennas is people that see them and purposefully bend them, which with some will mess up the cowl area of the trucK! So I think I'll stick with the stocker but shorter. Thanks again guys! I appreciate the info and suggestions. I do like the look of those stubbies, but I think I'll pass.
Jerry
Black 2010 Ford F250 XLT Crewcab Longbed 4x4 6.8L V10. Special Ordered. 295/70r18 Nitto Terra Grapplers on black powdercoated stock wheels, Harley Davidson Edition headlights. FX4 Grille. Recon smoked cab lights and mirror lenses. Factory bumpers and nerf bars have been powdercoated black.Husky Mudflaps,custom black 4" exhaust, AirAid intake, X3 tuner from 5 Star Tuning, AutoVentShade door sill protectors. Soon will black out the badges.
