Gents, I want to raise my 08 F350 3-4 inches. Does anyone have any suggestions as to manufacturer and what type? Also, does it efect the ride much? Thanks, gotta go throw my patio furniture in the pool before FAY does.
2008 Ford F350 4x4
6.4 Crew Cab
Oxford White
Medium Stone Leather
4x4 off-road package
Cape Coral, Fl
"LEAVE NOTHING BEHIND BUT FOOT PRINTS AND BAD MEMORIES"
We offer high quality systems by Icon Vehicle Dynamics, CST, RCD & BDS which are all backed by lifetime warranties. Here are a few examples:
__________________ Marty G. Truck Toyz Performance....Experience Matters! TDS Sponsor
Authorized Dealer for One Up Offroad, Rize Ind., Icon Vehicle Dynamics, CST, RCD, BDS, Bilstein, King Shocks, Sway-a-way, Amp Research, Vision X, Fab Fours, and much more!
I have the 4.5" CST suspension lift from Icon on my '08 F250 and love it!!!! I put 22" rims and 35" tall tires. The only problem I have found with it is a shutter at 5 to 15 mph. havent figured it out yet but i think its where the drive shafts meet up (brain fart... cant think of the name of that joint)... i think i just need to shim that up to correct the prob.
Overkill... you have delt with this system a lot any ideas of what can fix this problem
CST and Icon are different companys.
Did you install a carrier bearing drop kit?
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
What you are feeling is driveline shutter. Add 1"-1.25" of shims to your carrier bearing and that should resolve the issue.
I did not install myself I had a local shop install it. However it was the first time they had done this system. They told me it took two guys between 2 to 4 hrs to complete and that installation was simple. They were also very pleased with the people at CST when they called to learn about this system. I hope this helps you decide
My 350 is mostly a tow vehicle. It's the main reason I bought it. What does lifting do to towing ability or efficiency? I don't really like how low the truck sits but then it ain't a 4x4 and it is a duelly.
Bumping for a possible answer to my ? above. I really want to know. Thanks in advance.
2008 Job1 Lariat Crew Cab F350 Long Bed, DW, 330RE....with a whole lot of those fancy options inside. It looks like 'Dad's' truck and I like it that way.
When a truck is lifted, the frontal area is increased, which increases drag. Also, when a truck is lifted, larger rims and/or tires are added, which increases rolling resistance. These reduce the efficiency of your towing machine.
The higher you lift and the larger the wheels, the less efficient your truck will be for towing.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, 37x13.5x17 Tires, 4.88 Gears, Turbo-back Exhaust, Gauges, Air Bags...
I installed 2 1/2 " leveling kit on front $100.00 and firestone air bags on rear $260.00, 35" tires no problem 37" will probably fit. did it myself in the driveway 2008 f350 4door drw w/2" wheelspacers
Thank you. I suspected as much.
