Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 08-14-2007, 01:52 AM   #1 (permalink)
Malike25's Avatar
My Photos: (13)
Lift Kits for 2008 F-250
I just purchased a 2008 F-250 FX4 and I'm planning on lifting it w/in the next few months. I traded in a 2003 F-250 w/an 8" Fabtech Coil-over conversion kit on it and I did not like the ride. I do not want to go too high on the new truck. I've been seeing alot of Donahoe Racing 4.5" kits on the 08's w/37" tires. Are there any issues w/clearance? When off-roading do the tires rub on the wheel well?? My 38" tires would hit my wheel wells when off-roading and that was with an 8" lift. What lift kits are you guys using and how's the ride??
P.S.
I'm looking at the followin kits:
1) 6" ProComp Double XX
2) 6" Rize Kit w/King Reservoir Shocks
3) 4.5" Donahoe Racing
With any of the kits above I will be going w/37x13.5x20 Toyo Open Country MT's and 20" wheels.
Please help w/you feedback. I posted a pic of my new truck below.
Thank You!
http://i110.photobucket.com/albums/n...e25/08F250.jpg
2008 F-250 FX4 6.4L, 4" Rancho lift kit, Fox shocks on all 4 corners, Deaver 3" leaf springs on the rear, AMP Research step, 35" Toyo Open County M/T, 20" XD Series Hoss Chrome Rims, 1400 Watt sound system, Edge Evolution from xtremediesel.com, and very soon a Dual Exhaust (Don't know what brand)!
Malike25 is offline
Old 08-14-2007, 06:06 AM   #2 (permalink)
Re: Lift Kits for 2008 F-250
I to am looking to lift my truck alittle. I have an 08 F350 FX4. I would like the same info. Mine is a daily driver, so I don't want a huge lift and I want to make sure I don't have any rub issues with tires.
I got a price quote for a fabtech 6 inch coil over shock lift and Nitto 35 inch tires and rockstar rims. I thought 9500.00 was a little nuts. So did the wife. I never saw her do a regen before, but she did when I asked it I could buy it.
This will be my first lifted truck, so do you lose alot of ride quality when you lift a truck and how bad are you hurting the original parts on the truck?
Thanks for the help. I really like this place.
brandyguy is offline
Old 08-14-2007, 12:01 PM   #3 (permalink)
cannondale275's Avatar
my truck
Wow, $9500 is a lot. I did an 8 in Fabtech with dual 2.5 reservoir shocks up front and 2.5 in the rear. Added the 18 wheels and 37 in Toyo MTs for less than $6K here in So Cal.
Experience is something you get... right after you need it.
2008 F350 long bed Lariat 4x4 crew cab 6.4 oil burner. 8" Fabtech and 37" Toyo MTs.
cannondale275 is offline
Old 08-14-2007, 02:57 PM   #4 (permalink)
I'm pretty happy with my lift. I went with the 8" Fabtech basic lift and the only thing that really change ride wise is the rear is a bit stiff like my '04 F350 was stock and a slight shimmer in the steering wheel, which is my fault as I haven't put in my dual stabilizers up front yet. Front end bounces a bit more than before but that's because I have the standard Fabtech shocks in there. I'll go with Bilsteins once I figure out the right ones to get.
Bill
08 F-250 CC 4x4 6.4L, 8" Fabtech Lift, 38" Kumho MTs.
04 F-350 CC 4X4 6.0L, Magnaflow Exhaust, 6.5" Lift, 36" Iroks. (totaled)
Mustang92 is offline
Old 08-14-2007, 03:02 PM   #5 (permalink)
DSL_PWR's Avatar
I am going with the 2.5" Donahoe Kit myself and just 35"s at this time. Depends on cost but might do 4.5" kit and 37"s..
2008 F-250 6.4L Lariat Job 3 Truck.
Loaded Blue/Tan Two Tone with Camel Leather.
Rolling on 20's...
www.texastrends.com
DSL_PWR is offline
Old 08-14-2007, 03:35 PM   #6 (permalink)
Oh and of the three kits that you posted I would do the Rize. Mainly because of the shocks you specified...
Old 08-14-2007, 10:30 PM   #7 (permalink)
Hey folks. this may not help at all but i just ordered the 4.5 DR lift from www.sdhq.com. it was about 2300 shipped with the dual DR steering stabilizer and the drop down brackets because mine is manual (custom ordered for a stick). I also ordered 22in KMC XD-795 HOSS rims with 35in toyo AT's from www.rim-zone.com for 3050.00 shipped. Rim zone is awesome and great prices. My truck is an 08 cc diesel lariat white and gold. Ill post picks next week once done. Every one i talk to says that DR is worth the extra money because of the fantastic ride. But the 22 wheels with 35's may make it a lil bouncy.
iamvillani is offline
Old 08-15-2007, 12:41 PM   #8 (permalink)
Overkill's Avatar
My Photos: (31)
Malike25,
We have lifted a number of '08s with DR 4.5" on 37s at the insistence of customers. IMO they would work better with 35s under the 4.5" system but we have not heard feedback on any rubbing issues. The critical issue is that the rear springs are on considerable angle (relative to the chassis) so the more lift block added, the further back the axle is shifted. However the angle of the spring is designed to offset spring deflection so the axle has very little if any rearward movement under compression. Here is an example of a DR 4.5" on 37s
We also offer Rize systems which address the rear in three manners. First would be a special 3 leaf spring pack and block combination. The second is replacement rear springs. And the third would be OUO Traction Blocks. Each of these systems have their own advantage and all offset the center pins to properly center the tire within the wheelwell. Here are some examples:
Rize 8" w/Rear Springs on 37s
Rize 8" w/OUO Traction Blocks on 37s
OUO Traction Blocks
If you want to run 37s and have the ability to take the truck off-road without rubbing issues I would suggest at least a 6" system. In terms of ride quality I believe you will be very pleased with either the DR or Rize systems. These systems are very plush.
Let me know if you have any questions.
Marty G.
Truck Toyz Performance....Experience Matters!
TDS Sponsor
Authorized Dealer for One Up Offroad, Rize Ind., Icon Vehicle Dynamics, CST, RCD, BDS, Bilstein, King Shocks, Sway-a-way, Amp Research, Vision X, Fab Fours, and much more!
Visit us at:
www.TruckToyzPerformance.com & www.TruckToyzStore.com
Toll Free Ordering & Tech Support Line:
(888)776-8699
Overkill is offline
Old 08-17-2007, 01:23 AM   #9 (permalink)
i'm considering going with a pro comp 6" lift 22" KMC XD Hoss wheels Toyo 37X13.50X22 MT's . any comments before i pull the trigger on this?
08' FX4 CC short bed 6" Lift 37" Kumho's on Hoss 22's every option except PTO & rear ent. i don't ride back there! LOL
07' H3 lowered with 20's
97' Jeep TJ Sahara 6" lift Warn winch, Lockers, 4 wheel disc
2000SS Camaro conv.built motor, trans 12 bolt 600RWHP
87' Buick GN bone stock
69' SS Camaro Blown small block
57' Chevy 2 door wagom ZZ502 crate motor, 700R4 2004 Power Tour Long Hauler
71' Foose design Car Craft built SS/RS Camaro
The Insurance is killin me!
Ramair is offline
Old 08-17-2007, 06:01 PM   #10 (permalink)
Overkill's Avatar
My Photos: (31)
I don't wish to come across as bashing anyone so suffice to say that on a scale of 1 to 10 (10 being the best) I would rate the ProComp somewhere between 1 to 2 depending on how it is configured. Great wheel & tire combo though.
Marty G.
TDS Sponsor
Visit us at:
(888)776-8699
Overkill is offline
Old 08-18-2007, 12:53 AM   #11 (permalink)
All I can tell you is stay away from Pro-Comp lifts, I would get the toyo mt's they are the best tire out there, as for rims check out the Helo maxx 8's.
2001 f-250 4x4. Mods to date 4" magnaflow exhaust, AIS intake. 6" pro-comp lift,Helo Maxx 8 wheels with 35" Toyo mt's
ragged63 is offline
Old 08-18-2007, 11:18 AM   #12 (permalink)
Helos are NOT rated for our trucks..get a rim with a min. rating of 3000lbs!
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 08-18-2007, 11:57 AM   #13 (permalink)
Snake Eyes's Avatar
Hey iamvillani,
Is DR doing the custom work for you? I have an '08 with a 6 speed too and I heard that the kit would need to be moded but I didn't know who I'd get to do it. Are they still giving you the full waranty on it too?
Thanks,
John
2008 F-350 CC SRW FX4 156"
Black/Black, 5.4L/6 Speed, Manual transfer case/hubs, 4:10LS, 20's, Custom dual exhaust with straight pipes, Line-X, and Royal Purple in the pan.
Planned modifications:
6" Fabtech lift, 37's, 4:56's, 7.5L swap (yes, that's 460 cubic inches)
NRA Life Member
Snake Eyes is offline
Old 08-18-2007, 02:22 PM   #14 (permalink)
Overkill's Avatar
My Photos: (31)
We have installed DR kits are a couple of '05+ manual trucks (In fact SDHQ had DR call us to see how we did it). Yes, the radius arm backets must be modified but it can be done.
Marty G.
TDS Sponsor
Visit us at:
(888)776-8699
Overkill is offline
Old 08-18-2007, 03:35 PM   #15 (permalink)
Someone said helos are not rated for the f-series. Does this mean they won't handle it, or they don't say if they will?
mattmeyer05 is offline
