My Pioneer Navigation Install - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 03-01-2009, 07:37 PM   #1 (permalink)
Here are some pictures of my new Pioneer Premier AVIC F90BT. Installed it along with some JL Audio C2-570x speakers in my doors. I will move these speakers to the rear and get some nice JL components and an amp when I order my subs and the rest of my system.
Over sounds better than factory, the nav works well, has bluetooth for cell phones, ipod etc.
Its a nice unit with tons of options. Pretty affordable too.
08 CCSB White FX4
Spartan/Rudys Diesel/Icon/OUO/Interco/AmpResearch/Pioneer/JLAudio/Recon/Magnaflow/Rapid Hitch/Weather Tech/Line X/HID/Viper5901/CarriageWorks/S&B/Icce
InMotionJosh is offline
Old 03-01-2009, 09:34 PM   #2 (permalink)
danr1707's Avatar
nice, what is that hanging from the factory Ipod connector?
2011 F-350 6.7L SRW 4x4 FX4 CC LB Lariat- Job 2- Tuxedo Black
2008 F-350 6.4L SRW 4x4 CC SB King Ranch Job3 (SOLD)
2010 Fuzion 302 35' fifthwheel toyhauler
danr1707 is offline
Old 03-01-2009, 10:04 PM   #3 (permalink)
Thats a retractable ipod cable i had bought a while back.
08 CCSB White FX4
Old 03-01-2009, 10:12 PM   #4 (permalink)
danr1707's Avatar
That makes sense since its plugged into the ipod jack.
Do you still need it with the Pioneer? or does the new head unit control the ipod like the Kenwood?
danr1707 is offline
Old 03-01-2009, 10:17 PM   #5 (permalink)
No i dont need it with the new pioneer. It has its own IPOD connection and controls everything from the screen
08 CCSB White FX4
Old 03-01-2009, 10:25 PM   #6 (permalink)
danr1707's Avatar
Cool, nice upgrade.
danr1707 is offline
Old 03-01-2009, 10:38 PM   #7 (permalink)
danr1707's Avatar
I also like your choice of movies.
danr1707 is offline
Old 03-02-2009, 09:34 AM   #8 (permalink)
Thanks....thats actually a picture of my fiancee that I uploaded as my startup screen.
08 CCSB White FX4
Old 03-02-2009, 10:08 AM   #9 (permalink)
danr1707's Avatar
Smile
OK, then I like your choice of fiancee. lol
danr1707 is offline
Old 03-02-2009, 10:12 AM   #10 (permalink)
Thanks!
08 CCSB White FX4
Old 03-07-2009, 09:33 AM   #11 (permalink)
Fanuc's Avatar
Did you do the install yourself? if so how hard was it to pull the ford unit out and wire in the new unit?
Fanuc is offline
Old 03-07-2009, 06:38 PM   #12 (permalink)
I did it myself. Taking the ford unit out is super easy. Its 6 Bolts, and unlpug everthing and thats it.
Installing the new one is a little tougher as I soldered all the wires from the pioneer harness to the ford adapter harness. Also you need to ground a couple of wires in order to allow the video and navigation to play while you are driving.
Its easy if you know what your doing. If you have never installed a stereo I wouldnt advise attempting on a unit like this. It takes patience and little bit of planning.
08 CCSB White FX4
Old 03-07-2009, 08:39 PM   #13 (permalink)
Fanuc's Avatar
do they not make an interface for this unit to the Ford harness?
Fanuc is offline
Old 03-08-2009, 11:18 PM   #14 (permalink)
Yes they make an adapters harness but plugs into the factory ford harness and you must connect it to the pioneer harness. I always solder mine
08 CCSB White FX4
Old 03-09-2009, 10:53 AM   #15 (permalink)
danr1707's Avatar
They make a Pioneer/Ford harness for easy installs. For the Nav install there are more things to hook up than just batt/ign/ground and speakers so soldering is still a must. You need parking brake (ground), reverse wire, etc. Those are not part of the factory harness.
If your not comfortable soldering than you can use crimp connectors as long as you use a pro crimp tool (like Snap On). The cheap ones don't work well.
If your not comfortable crimping either than I suggust you do not attempt this install alone.
.02
Dan
danr1707 is offline
