Go Back   Diesel Forum - The Diesel Stop.com > 2008-Up Super Duties > '08-Up Upgrades and Aftermarket
'08-Up Upgrades and Aftermarket Upgrading and adding aftermarket equipment to your 2008-Up Super Duty.
Old 09-20-2009, 10:26 PM   #1 (permalink)
Need help on lifting 2WD
OK. I have a 08 F250 2WD. It is time to get new wheels and tires. I what to put on 18" wheels with some tires that I do not know what size yet. I want a little bigger tire with a lower profile look. I also want to, or think I need to lift the truck just a bit. I really just want a subtle look. I was trying to search the galleries to find the exact look I was looking for.
Any suggestions on lift's or what I should do? Also how about tire brand and size. I do not want to compromise ride quality. While it is a daily driver we tow a 32" toy hauler in the soft dirt. I don't want to mess that up with driveability either.
goin2drt is offline
Old 09-25-2009, 08:29 PM   #2 (permalink)
DSL_PWR's Avatar
Just do a leveling kit and you should be fine. Not sure what all is available for the 2wd trucks but I am sure a google search or search on here might reward you.
2008 F-250 6.4L Lariat
DSL_PWR is offline
Old 09-25-2009, 11:23 PM   #3 (permalink)
There's almost nothing available for 2WD F250's. The only thing out there that I can think of right now is a 6 inch kit from Fabtech. Every leveling kit I've seen out there specifically states it's for 4WD. So I guess we're stuck.
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is online now
Old 09-26-2009, 04:33 PM   #4 (permalink)
The largest lift I have been able to install (while still being able to bring the alignment with-in spec.) on a 99 – on Superduty or Excursion 4X2 with stock radius arms and or stock A arms is 3”. By using a 2.25” spacer under the front coils it will yield 3” of lift at the front tow hooks. Any time I use 2.25’ spacers under the coils, I have to use the 0 – 4 degree fully adjustable wheel alignment bushings from Stempf Automotive. The part number is HXR-94 and the last set I purchased (4-6 weeks ago) cost 19.26 ea. The total cost for the bushings and the shipping to my door was under $50.00. You can install the bushings your self to save some money and then bring your truck to your favorite alignment shop. Make sure that you completely REMOVE the pinch bolt before you try to remove the stock non-adjustable bushing. The bolt goes through the stock bushing and I have seen many people break-off a piece of the top flange trying to pry the stock bushing out with out removing the bolt.
Hope this helps out.
vetmxrider
2002 7.3 F350 CCLB
4" Turbo-back Pinnacle (Jerry Jardine) Exhaust
Racor 2 Micron / 90 G.P.H. Fuel Filter
Baldwin BT111 External Trans Filter
OilGuard EPS-20 Oil Bypass Filter
Baldwin B5134 Coolant Filter
Dual External Trans Coolers
DieselSite 203 Thermostat
D.I.Y. Nappa 6637 Intake
SuperChips 1705
Bilstein Shocks
Zoodad Mod
vetmxrider is offline
