Need a recomendation on these companies for a 6 inch lift:
Pro-Comp
RCD
Superlift
BDS
These are the ones I am looking at for my budget on my 2008 Ford Crew Cab Short box. Pro-Comp is offering 20% off parts plus free install through 31 July. Most people tell me to stay away from Pro-Comp though.
Just looking for durability and one with a good ride. My buddy tells me most these I have listed above are pretty comparable. I also like Rize but they are on the pricey side. I also like ICON but they don't have a 6 inch and I don't want a 7-inch.
My truck is my daily driver, but where I hunt and camp is tough 4x4 country in the Rockies.
FYI just because a company says its a 6" lift ..could be higher or lower. Icon would be the best for ride quality but all will get the job done. Good shocks make a huge difference....order your kit without shocks and get Bilsteins.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
I have a 6" Pro Comp lift on my 2003 6.0 and love it. The truck drives straight and rides awesome. Pro comp makes a good lift and with that discount I would strongly consider going with them.
Fabtech makes a really good affordable lift. My buddy has owned a reputable off-road shop and has built tons of jeeps and ground up rock crawlers over the past 12 or so years. He highly recommends Fabtech for durability, geometry, customer service, and warranty. I'm getting the 6" radius arm drop installed with Bilsteins for $2,200 today. I'm with you, I actually have to use my bed on a regular basis so 6" was the max height I wanted to go.
2008 F350 Lariat Crew SB - 6" Fabtech Radius Arm kit, 20" KMC black Monsters, 37" Toyo MTs, Alpine 505 DVD, Alpine 5x7s, Fosgate amp and 10" Sub, more to come...
2008 Harley Softail Deluxe - slammed, apes, fishtails, etc.
Pro-Comp
RCD
Superlift
BDS
The Icon, RCD and BDS systems will offer you the best ride quality and lifetime warranties. The 6" RCD is a 4-link system which is a big plus, however it is a bit more expensive. You could also opt for a Icon 4.5" and add their 1" TEI spacers and 6" rear blocks (this combination will comparable in height to most 6" systems). Here are some of the systems we offer: 2008 F250/F350 SRW 4wd - Truck Toyz Store
Let me know if you have any questions.
__________________ Marty G. Truck Toyz Performance....Experience Matters! TDS Sponsor
Authorized Dealer for One Up Offroad, Rize Ind., Icon Vehicle Dynamics, CST, RCD, BDS, Bilstein, King Shocks, Sway-a-way, Amp Research, Vision X, Fab Fours, and much more!
no offense to cary and overkill, but if he is talking budget, a 4 link is probably out of it.
I will offer some real world expierence. I have the pro comp, with the pro comp arms. I did however opt for bilstien shocks. The kit came with brake lines, arms, front coils, rear add a leafs and blocks, trac bar bracket, pitman arm and carrier bearing shim. It easily clears my 37's. It rides as well as stock if not better. It tows awesome(i just took a trailer, where me and the truck weighed in at 17K), it didnt squat, sway or anything else. The fit was great, the directions easy to follow. I highly recommend this kit, especially for the money.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 Pro Comp Xtreme Mud Terrains Try the SEARCH Button Because It's Probably already been asked
What I and Overkill recommend ..the Icon kit doesn't require a 4 link kit which could be added later if he desired.
X2 for the Rize kit also.
Cary
2006 Yamaha FJR1300
fabtech IMO, is what you are looking for, for the money it is a great lift
08 F-250 Black FX4 Every option
SCT 158 HP TUNE DPF Delet
S&B Intake
RBP Exuast
Straight pipe from DP Back
8" Fabtech lift
38"15.5"20 baya claws on rockstars
Rize traction bars
rize duel stabilizer
fox res. racing shocks all corners
It really depends on how much dependability you need with a suspension lift...It sounds like you will be stressing the suspension components and actually taking advantage of the lift when hunting off-road...If you can at all swing it, I would go with the 4-link system...you won't regret it! More durability and stability off-road...I would go with anyone BUT Pro Comp...The suspension on these trucks is of second importance only to the power-train, don't go cheap 40-50K miles down the road you will be glad you went with a better system.
I agree!!!
__________________ 2007 Ford F250 CC 6.0 4x4 Lariat Outlaw Edition, 7" DR Lift, 37/13/22 Toyo M/T's, 22x9.5 KMC Black Hoss, AFE Stage 2 P/G 7 w/ Pre-Filter, SCT w/ DJ's Looney, MBRP Turbo-Back Off-Road Exhaust, Kenwood 8120 DVD, Valentine One, Amp Steps, 08 Shaved Rear End Conversion, 08 mirrors, Recon Tailights, 3rd Brake Light & mirror lights, Mag-Hytec Diff Covers & Trans. Pan, Royal Purple Everywhere, Retrax Bedcover.... much more to come...
All the research ive been doing, pro comp xxx series. a bit pricey, but hands down the best kit on the market.
Keep researching. That is a position clearly occupied by One Up Offroad.
