Where is the (+) Horn Wire? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008-2010 Upgrades and Aftermarket
2008-2010 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2008-Up Super Duty.
Old 09-21-2009, 02:58 PM   #1 (permalink)
TexasTruck's Avatar
My Photos: (13)
Question Where is the (+) Horn Wire?
I've searched "+air +horn +install" and I find tons of information for pre-2008. Either I'm missing it or the wire and tracer colors have changed in 2008. The closest information I found is the horn wire is underneath the fuse box on top of the drivers side front wheel well in the engine compartment.
Does anyone know where to tap the (+) horn wire?
Thanks!
Scott
2008 Silver F250 FX4 6.4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness / Custom Driveline
"A problem is an opportunity in work clothes"
TexasTruck is offline
Old 09-23-2009, 01:47 AM   #2 (permalink)
The horn has constant 12v + so you have to use a - negative trigger. If you are wanting to trigger it with something that only has a + output, then you will need to use a relay to change the polarity.
the wire is yellow with a red tracer. You can get it at the switch in the column or in the smart junction box in the passenger kick panel. black 52 pin plug (B), pin 41
2009 F-350 6.4 4X4 CC SRW King Ranch
2005 F-350 6.0 4X4 CC DRW King Ranch
2000 F-350 7.3 4X4 CC DRW Lariat LE
SPL2K is offline
