no you would have to order a cab and chassis truck first, or buy one off the lot and then take it to a body upfitter that would install the tow truck body on your rig. However if you find the right dealer they probably will have the means to help get you exactly what you want and need. By that i mean that the dealer probably has certain upfitter companies that they deal with on a regular basis and would then be able to get your truck rigged up.
RIP 2008 CC LB 6.4...Rolled 3.5 times and walked away with only 4 scratches....Brand new 2010 F-350 CC LB 6.4 Lariat SRW, Camper package, Snow plow, dual alternators, cab lights, Back up camera and tail gate step, Rhino lined box, 6 inch pro comp lift kit, 35"x 12.5 toyo Mt tires, Buckstop outback bumper, 12000 warn winch, 4 lightforce driving lights on bumper, Spartan tuner and dpf delete with 4 inch mbrp exhaust, Winter studded cooper tires...stock size.
