Hydroboost - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 Ordering Information
2008- 2010 Ordering Information Discussion of ordering and status of an order of a Super Duty truck. All engine types allowed.
Old 07-27-2009, 06:31 AM   #1 (permalink)
gnxtc2's Avatar
Hydroboost
Is Hydroboost standard on the 2010 or you have to order the dual alternators to get it on a F350 SRW?
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 07-27-2009, 08:39 AM   #2 (permalink)
SmokeyWren's Avatar
My Photos: (44)
There are no power brake options on 2010 models .
Hydroboost brakes are standard with the diesel engine. Vacuum boost brakes are standard with gasoline engines. Diesels don't make vacuum, so vacuum-powered brakes are not available with the diesel engine.
For details, download and print out the 2010 Superduty Pickup Order Guide from
Sunrise Ford Fleet - Your Super Duty Truck Headquarters
Ford played around with vacuum-powered brakes on diesel-engined trucks a coupla years ago, but I don't think they ever made it to market. The required big vacuum pump was probably too expensive.
SmokeyWren is offline
Old 07-27-2009, 06:17 PM   #3 (permalink)
gnxtc2's Avatar
On the OBS trucks, we have a vacuum pump. The OBS F-450 (Super Duty Mono-Beam front axle) had the hydrpboost set up.
The reason I asked was when you clicked on the "details" on Fordvehicles for the dual alternator, it stated hydroboost brakes comes with the dual alternators.
Billy T.
gnxtc2@aol.com
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 07-27-2009, 09:39 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Which is true, but in a round-about way.
Dual altenators are available only with a diesel engine. So if you have dual altenators, then you'll have hydroboost. But it's because of the engine and has nothing to do with the altenators.
Apparently the webpage designers are geeks who don't know much about Ford SuperDuty trucks.
