What were the towing ratings on these trucks and would the 2010 be a good upgrade even though its a gasser?
I had a '99 4x4 CC V10 and pulled a 14K lb 5er. It would down shift quickly on any overpass. I would kick it out of Cruise when hitting any grade. When going up the Cajon Pass on the I-15 I would put it in 2nd and let it wind up. I managed 55 mph up the pass.
It wasn't perfect, but it did the job. The new V10's are far superior than the '99 version.
'08 F350 Lariat CC 6.4 DRW 4.10 4x4 manual hubs and 62 gal fuel tank.
The newer V-10's from 2005-2010 with the Troqueshift are way better than the older V-10's with the E4OD trannys and even better than the stock 7.3's IMHO. Why do you think there are 90% V-10's in Class C motor homes and even a good percentage in Calss A motor homes for gassers? Dependability and workhorse engines, that's why. You just don't see many V-10's in the shop for engine problems on these heavy motor homes.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies. pappy's truck
I don't believe that the F-53 chassis was ever available with a diesel so your Class A conclusion is specious. As to the vans they have always been airflow/cooling capacity limited so the choice between a 235/440 diesel engine and a 305/420 6.8 gas is pretty easy, especially in a van chassis.
That being said we have a 06 V-10 powered F-450 that I might consider as being a close match to some of the earlier 7.3 powered F-450's we have had for lighter loads and on flat ground. Put a heavier load on it and head through a mountain pass and I will pass thanks.
With diesel being ~15% cheaper than gas here the V-10 powered truck does a good job of holding the cement down in the shop though.
That is until you get a dose of bad fuel or it jells up on you just as you were going over that pass you mentioned, then the V-10 would chug on by. It's no wonder that 90% of the F-450 chassis models made into C class mortor homes were/are Ford 6.8 V-10's. They are tough, reliable and don't puke on the side of the road. But hey, I know you diesel dogs love that diesel smoke and it is so macho to work on them and smell like diesel all the time. No problem here.
