Ignition 'ping' with V10?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 Gas Engines
2008- 2010 Gas Engines Discussion of the gas engines available in the 2008- 2010 Super Duty trucks
Old 04-07-2009, 02:26 PM   #1 (permalink)
Cowcop's Avatar
Exclamation Ignition 'ping' with V10??
Good day folks...
Our 'Cow Boss' has a new 2008 F350 with the V10 and a manual transmission. Fuel is obtained from a farm tank and he uses injector cleaner on occassions. The truck is almost never on the highway and is never driven long distances.
He is complaining about 'ping' when accelerating and notices it more when towing the stock trailer. Does this sound like a fuel issue or does the beast have to see the highway to get cleaned out?
99.5 F-350 S/C 4X4 - gone
2012 F 350 S/C 4X4 Lariat - stock as a rock for now...
Cowcop is offline
Old 04-07-2009, 10:37 PM   #2 (permalink)
Pappy19's Avatar
My Photos: (6)
I don't know the answer to your question, but here's my take. I have an '08 V-10 with the Torqueshift Automatic and a 4.10 rear. I have towed heavy on 4 different occasions from Idaho to El Paso and back over those nasty mountains, and I never had a single ping. I have installed the Diablosport Predator programmer in the "middle" 91 octane tow/performance setting and this truck hauls balls. They also have a 93 octane, super performance setting, but I have kept it on the middle setting for over 25k of my 32k miles. No use in messing with success IMHO. This truck kicks butt and never complains and is easy on the pocket book compaired to a diesel. You might give the Predator a try.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 04-08-2009, 12:58 AM   #3 (permalink)
Cowcop's Avatar
Thanks Pappy...
I am going to sample his fuel source and will see if anything rears up there. We will look into your programmer and install it without the 'Cow Boss' being aware! This way we will hear how the truck is running based on his own 'seat of the pants' discovery.
Will post when results are in.
Cowcop is offline
Old 04-08-2009, 09:26 AM   #4 (permalink)
akrewat's Avatar
If you already have a ping, it's not the best idea to put a programmer into the mix
I suspect the gas supply is bad, although the V10 has a knock sensor so it should be able to deal with it.
Are you sure it's not a heat shield or something else rattling ?
'01 F250SD V10 auto 4x4 SC SB Volant CAI, ebay headers/y-pipe
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
Old 04-08-2009, 01:14 PM   #5 (permalink)
Cowcop's Avatar
Smile
Good morning...
I have only driven the truck once so I cannot comment....I HEARD NADA!
I too suspect fuel supply issues as his tank is older than me and has not had a lot of tlc over the years.
I will not try a programmer until the fuel is checked/passed and only then will we attempt to bring 'Cow Boss' into the new age!
P>S> Another issue may be the farm dye???
Cowcop is offline
Old 04-25-2009, 12:18 AM   #6 (permalink)
Cowcop's Avatar
Smile Update!!
I took the V10 for a cruise with CowBoss in the passenger seat. Cutting to the chase....I could not make the truck ping in any situation although my mostly deaf friend could 'hear it a little'....
I am calling a false alarm as this truck real seems very responsive when revved a bit, and in fact, if the diesel situation does not remedy itself in the near future, I would consider the V10 in a flash!
Cowcop is offline
