warning chime on 08 F-350 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 Gas Engines
2008- 2010 Gas Engines Discussion of the gas engines available in the 2008- 2010 Super Duty trucks
Old 02-19-2009, 05:56 AM   #1 (permalink)
Is there any way to disable the hellish chime that sounds with no seatbelt, lights on, keys in ignition? We're in and out of the frigging thing, and with most other vehicles one can pull the key out an 1/8 of an inch or so and quiet the chime, no so with this Ford.
It sounds like it comes from near the headlight switch...
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is offline
Old 02-19-2009, 08:22 AM   #2 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Wink Chime and light killer
Look here.
Shawn
2008 F-450 JOB-1, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viair 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm. Chime/Light Killer Mod. Polished Job-1 exhaust tips. Transmission upgraded to JOB-2 filter, pan, and lines. External filter eliminated.
PICTURES
GEARJAMMER is offline
Old 02-19-2009, 08:36 AM   #3 (permalink)
Phil G.'s Avatar
Unless the 08's have changed, there is a proceedure in your owners manual to disable the seatbelt chime. It's a PITA to do but well worth it. As far as the headlight chime, I am not aware of how to do this one but thats the one I wanted to keep anyways, and it has been used a few times
http://philztruck.piczo.com/?cr=7 Updated February 2009!
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Alpine W205 DVD head unit with Blackbird 2 GPS, and Parrot Handsfree Blueooth + 7" O/H Monitor,Sirius plug in receiver, Kenwood KAC-8492 720w 4ch Amp driving Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, Infinity 611a Class D mono amp driving 2- Kenwood W2509 10" subs in custom box Cobra night-watch w/ dual wilson 2000's, 100gal polished alum fuel tank, Reese 5th hitch, Anderson Tool aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,RamMount laptop mount.
Phil G. is offline
Old 02-19-2009, 04:46 PM   #4 (permalink)
GEARJAMMER's Avatar
My Photos: (10)
Talking Chimes
Originally Posted by Phil G. View Post
Unless the 08's have changed, there is a procedure in your owners manual to disable the seat belt chime. It's a PITA to do but well worth it. As far as the headlight chime, I am not aware of how to do this one but that's the one I wanted to keep anyways, and it has been used a few times
It's the same on the 08. It won't turn off the seat belt chime when you first put the key in the ignition but it does turn off the seat belt reminder. If you're not good at rubbing your tummy and patting your head you can have a tech disable it on the computer.
If you read my above post you will have an on/off switch for your chimes and interior/bed lights.
Shawn
PICTURES
Old 02-21-2009, 03:08 AM   #5 (permalink)
Many thanks for the detailed mod - with a picture, no less. I'll give it a try.
Greenie is offline
Old 04-27-2009, 12:42 PM   #6 (permalink)
My Photos: (5)
Send a message via AIM to ffxhub
Chime killer
So will the steps in the owners manual kill the seatbelt reminder chime for ever or do you have to do it each time you start the truck??
2008 F-250 KR V10 4x4 CC LB - Job 2 - ARE Topper w/ roof racks, 20% Tint - Gas Mileage
1985 F-150 XL I6 4x4 SC LB - 3 inch body lift, 35" BFGs, Alpine stereo and speakers, PPI Amp
ffxhub is offline
