why only the 4.10 with the V-10 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 2008-2010 Ford Super Duties > 2008- 2010 Gas Engines
2008- 2010 Gas Engines Discussion of the gas engines available in the 2008- 2010 Super Duty trucks
Old 12-26-2008, 10:40 AM   #1 (permalink)
JDeereGn's Avatar
I am considering a new F-250 4 x 4. I see no reason why Ford will only put the 4.10 behind the V-10 but use a higher ratio behind the 5.4 and even higher with the 6.4. Does anyone know why? It only seems logical to me that the stronger V-10 would perform even better than the 5.4 with the higher gears and certainly the MPH would be much better. Off course some HD towing performance would be lost but to me it seems the fuel savings would off set that. I have even looked at changing the ratios in a new 4x4 but that is over 2K. I would appreciate comments. thanks Ralph
2003 F250 4x4 6.0 PSD Auto trans
"All gave some, some gave all"
http://community.webshots.com/user/JDeereGn
JDeereGn is offline
Old 12-26-2008, 12:33 PM   #2 (permalink)
JDeereGn,
seems that there is little demand for the V10. I asked this question myself many times as I would love to avoid to 4.10.
Btw. Do you know about the current rebates? How much to expect to pay for a V10 these days?
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
pictures
JimJoe is offline
Old 12-26-2008, 02:37 PM   #3 (permalink)
Pappy19's Avatar
My Photos: (6)
I purposely ordered mine with the 4.10 which I think is the best rear end ratio available. I do know that you can order the V-10 with lower ratio's and maybe you can get a 3.73. I think the 4.10/V-10 combo is about as good as it gets for all around performance and mileage is tolerable.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 12-26-2008, 03:52 PM   #4 (permalink)
Originally Posted by Pappy19 View Post
II do know that you can order the V-10 with lower ratio's and maybe you can get a 3.73.
Sure? Any proof here? Looking at the orderbook V10 and 3.73 is not allowed.
Jim
2007 Suburban LT3
pictures
JimJoe is offline
Old 12-26-2008, 04:56 PM   #5 (permalink)
If you look at other forums, you will find that 4.10 is the minimum that is a good combo with the 10. Most guys order the 4.30's and if they don't buy new they end up swapping them in. It seems the modular v10 likes revs and pulls best at a higher rpm. Do a search at Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source. and you will find a TON of info on this very subject.
2009 - 250SD - Lariat - 4X4 - SB - SC - V10 - 4.30's - Royal Red/Black. Going in on trade the end of the month.
2012 - 350SD - Lariat - 4X4 - SB - SC - 6.7 - 3.55's w/elock, Ingot Silver. Being built Feb 17th. Should pick up around the 1st of March...
taken is offline
Old 12-26-2008, 05:00 PM   #6 (permalink)
JDeereGn's Avatar
Pappy what mph are you getting with the 4.10? The 4.10 is definately the highest you can get with a V-10. I would get a truck almost like yours except for a long bed.
JDeereGn is offline
Old 12-26-2008, 09:50 PM   #7 (permalink)
I'm getting around 10 MPG in my daily driving. I have seen just over 14 MPG on the lie-o-meter at lower interstate speeds (55 to 60ish), but when I jumped up to around 75 or so, my MPG dropped down considerably. My one and only road trip with this truck (so far) netted me around 11.5 MPG hand-calculated IIRC. If I had it to do all over again, I would definitely have waited and got 4.30 rear end. My 6.0 had the 3.73 and I really didn't think that was that great of a combination when pulling my trailer. I believe that truck would have been better with 4.10. But that is just my $0.02.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 12-26-2008, 10:08 PM   #8 (permalink)
Do you mean highest numerically (steepest gears) or highest gear ratio? Because if you read up on the V10, higher numerically is much better.
taken is offline
Old 12-27-2008, 10:30 AM   #9 (permalink)
Pappy19's Avatar
My Photos: (6)
If you really are asking mph, I have a Diablosport Predator programmer installed since it had 5k on the odometer, so the speed limiter was turned off. Fastest that the speedo has shown is 96. Haven't had any occasion to go faster. If you are talking about mpg, with the Predator on the "middle" 91 octane position, and with the Air Raid intake system, I am getting 11-12. Towing heavy it gets 9-9.5. If you are towing alot, then I would recommend the 4.30. If you plan on towing a large 5th wheel or are hauling heavy every day, then the 4.88. I think the lower the ratio, the worse your mileage will be. To me, the 4.10 is the perfect ratio. Plenty of poop and pulls good. I wouldn't change mine.
pappy's truck
Pappy19 is offline
Old 01-10-2009, 10:13 PM   #10 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
If you get a truck with 4.10 gears and want 3.73 gears you could add a set of 285/75/16 or equivilent size and accomplish pretty close the the final drive ratio.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 01-11-2009, 07:21 AM   #11 (permalink)
This is what I just wanted to add. For the King Ranch why not go from 18 to 20. This gets down the ration from 4.10 to 3.69. What I do not know is the influence on MPG as the rig gets to sit 1in higher.
Jim
2007 Suburban LT3
pictures
JimJoe is offline
Old 01-11-2009, 07:32 AM   #12 (permalink)
jonrjen's Avatar
Lubbockguy1979 Makes a great point. And it would be much cheaper than a re-gear job. However if you are thinking of going over sized tires and wheels somewhere down the road, you may want to order the truck with the 4:30 ratio. Then after adding the over sized tires and wheels you will end up somewhere in the 4:10-3:73 range.
I have the 4:10 on my F-250 with a manual transmission, and it is a good set up.
If you read up on post dealing with MPG on the V-10, you will note that this motor is not know for giving good mileage with what ever rear end ratio it has. It is know for providing long dependable power with inexpensive maintance....but as for MPG....she does tend to drink a little much at times.
2008 F-550 Regency Conversion Hauler 6.4 PSD
2006 Ford F-250 XL V-10 6-Speed
2006 Ford F-150 Crew Cab XLT
2005 Lincoln LS Sport
1977 F-600 Cab-Chassis V-8 4-Speed 2 Speed rear
1997 Travel Supreme 40' triple slide 5th wheel
38 +or- head of Texas Longhorn Cattle..."REAL COWS Have HORNS"
jonrjen is offline
Old 01-22-2009, 08:05 AM   #13 (permalink)
Smokewagun's Avatar
My Photos: (9)
I don't understand why the 4.10 and 4.30 gears are the only ratios available with the V-10 in trucks, either. The Excursion, I think, came with a 3.73 rearend. Historically, the Excursions get better fuel economy across the board with any engines than it's F-250 counterpart. I'm sure there is no weight difference worth nothing, either. My wife and I had a 2003 V-10 Excursion and could pull just over 16mpg on our highway trips down to Pigeon Forge every year with a fully loaded vehicle, air conditioning on, and cruise set at 72mph. This wasn't a one time trip, either. Now, winter driving around town, well... about 10-11mpg.
I can understand that some say the different size wheels and rubber (larger) on the trucks with the 4.10 are about as effective as the 3.73 gearing, but the mpg numbers don't prove that. I see ford offers the SFE package on the 2009 F-150, so why can't they offer something similar on the other Superduty drivelines? If you order the smoker's package, you know your going to smoke and the interior of your truck will smell like an ashtray. So, if you order the 3.73 gears with the V-10, your highway mileage will go up, but your towing capabilities will drop and your truck may be a dog out of the hole. Okay. Remember the old days when you could order a "highway axle" on a car? My old 1976 Cutlass had a highway axle. It was a bear to get moving, but once you hit highway speeds, it was unstoppable. My old roommate from college found out the hard way his Berlinetta wasn't a match to my Olds cruising down Highway 51.
2010 Ford F-250 Superduty Harley Davidson. Navigation. Moon.
Smokewagun is offline
Old 02-12-2009, 09:49 PM   #14 (permalink)
Charlie98's Avatar
My '99 F250 V-10 5-speed had 3:73's and I would get 14-15mpg in combination driving. No one would believe me.
My new '09 V-10 has an automatic and 4:10's, I'm only averaging about 10.5mpg but it only has 1200 miles yet. I would rather have 3:73's but, really, in the end it isn't much different.
My '99 turned 2250rpm at 70, the '09 turns about 2350rpm or so at 70. The '09 is way faster off the line but part of that may be the automatic.
Charlie98 is offline
