Greetings from San Diego, - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > New Member Introductions & Forum Assistance
New Member Introductions & Forum Assistance If you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
Old 10-18-2009, 02:55 AM   #1 (permalink)
4x4grey88's Avatar
New to this forum but not to forums in general. I recently purchased (this year) a 2003 F250 Crew with a 6.0 diesel. Still believe that I got a great deal on this truck even though I am finding out the real reason he sold it out. I will post all that in the correct thread. I hope that I can both give and receive help from this forum. I am not all that well versed in diesels, as this is my first diesel. I am a fast learner and fairly good in the mechanically inclined areas.
Jim
4x4grey88 is offline
Old 10-18-2009, 03:31 AM   #2 (permalink)
boomboom's Avatar
Welcome Jim. The first thing you really need to do is fill out your signature ( go to my account in black bar above) with discription of your truck like you did in your post here so when you ask questions or make comments people know what you got. year ,model and sense your an 03 include the 6.0 because 03 had 7.3's also. Some people here take things alittle personal but MOST are GREAT PEOPLE !! There is alot of info. HERE. Again WELCOME Bill
boomboom is offline
Old 10-19-2009, 08:45 PM   #3 (permalink)
aekrogh's Avatar
Hi Jim. I'm from the Escondido/Valley Center area. See you on the road.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
Old 10-26-2009, 04:19 PM   #4 (permalink)
Hey Jim,
Hows it going, I live up in the OC, keep the look out for our chevy dually sporting the Green Oil Colors.
Colin
colin@greenoil is offline
