hello from edmonton area - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > New Member Introductions & Forum Assistance
New Member Introductions & Forum Assistance If you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
Old 07-24-2008, 09:41 PM   #1 (permalink)
hey was hopeing someone could tell me if there is a one way check valve on my 83 f250 6.9 fuel bleeds back if it sits for any lenth of time if so where and how easy to change
kwilker is offline
Old 07-25-2008, 09:27 PM   #2 (permalink)
sheepman's Avatar
My Photos: (6)
Welcome to the TDS! Your question would be best answered in the IDI section for 6.9 and the 7.3 engines. But to answer your question, you may need replace your return fuel line that goes from the back of the engine on the drivers side. Remove your air filter and you will see it. It comes off the metal pipe that runs from your IP pump to the rear of the motor on top of the engine, drivers side. Also, you may need new injector return lines, injector caps, injector O rings or your IP may be wore out. Do your injector T caps leak, does your IP weap fuel from the bottom weap hole? Just a couple things to look at. It maybe that the rubber line needs to be fixed or replaced. Try the 6.9 section those guys are great help!
sheepman is offline
