How do I post a question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > New Member Introductions & Forum Assistance
New Member Introductions & Forum Assistance If you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
Old 11-06-2009, 01:00 PM   #1 (permalink)
I am very new to this on line question and answer stuff.
How do I post a general question about my 2000 F250.
pcatanza is offline
Old 11-06-2009, 11:38 PM   #2 (permalink)
bugman's Avatar
My Photos: (18)
Just go to the correct forum for your truck, put in the title of your post ask your question. If you get into the wrong forum don't worry a moderator will move it to the right one for you.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-12-2009, 11:30 AM   #3 (permalink)
Don't see a place
I go to the 1999-2007 Super Duties forum, but I don't see a place to put in the title of a post or ask a question.
Maybe I need to polish my glasses.
pcatanza is offline
Old 11-12-2009, 04:35 PM   #4 (permalink)
Dick Cutting's Avatar
My Photos: (27)
After you open the correct forum for your question, at the top of the list of threads in that forum there is a button that has "New Thread" on it. Click on that button and you will get the new Thread window to post the title and the question.
TheDieselStop.Com Moderator & Photo Editor
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, Currently 2/2012 - 266K+ miles
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, Currently 2/2012 - >183K+ miles
Dick Cutting is offline
Old 11-12-2009, 04:37 PM   #5 (permalink)
69mach1377's Avatar
I think you just posted a question...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 11-12-2009, 06:13 PM   #6 (permalink)
No Button
My screen does not have the "New Thread" button.
Is there a setting I need to change.
I added a screen print attachment, but I am not sure if it attached.
pcatanza is offline
Old 11-12-2009, 07:17 PM   #7 (permalink)
69mach1377's Avatar
So how did you start this thread?
Old 11-13-2009, 10:02 AM   #8 (permalink)
I see the new thread button only on the New Member Introductions & Forum Assistance screen, so that is what I used to make the first post.
Attached is the screen I see there.
I thought I would see the new thread button on every forum.
pcatanza is offline
Old 11-13-2009, 12:44 PM   #9 (permalink)
boomboom's Avatar
Go back to first page you attached and click on engine size of your vehicle, or the area that best suits your question, same spot as new member area will be" NEW THREAD "click on that. You just didn't pick a catagory to post your new thread. No biggie
boomboom is offline
Old 11-13-2009, 01:18 PM   #10 (permalink)
I found it
Thank you so much for the great help.
pcatanza is offline
Old 11-13-2009, 01:43 PM   #11 (permalink)
boomboom's Avatar
NO PROBLEM Make sure you fill out your signature with all info on your truck so it pops up on the bottom of every post you make.You can find that in the My Accout section.
boomboom is offline
