New Member Introductions & Forum AssistanceIf you are new to the site, please stop in to say "hello" and tell us a bit about yourself. For members having a hard time with a forum feature, this is the place to find answers and ask questions.
How do you upload a picture to a thread? it brings up a window that has a few pics that i have downloaded to my pics but can not figure out how to get it into a thread. trying to add a pic of my truck to the lets see your trucks thread.
thanks for any advice, chris
__________________ 2005 F-250 CREW CAB 6' BED - 6" PRO COMP LIFT ON 22" DIESEL RIMS WITH NITTO GRAPPLER M/T 35'S - AIRID AIR FILTER - HIGH IDLE MOD - 4" EXHAUST - MAG HYTEC FRONT AND REAR DIFFERENTIAL AND TRANNY COVERS - ARP STUDS - SCT X3 - BULLY DOG PMT(for monitor only) - SMOKE SWITCH - RBP GRILL - RECON CAB, BRAKES, 3rd BRAKE LIGHT and EXTREAM TAILGATE BAR - HARLEY HEAD LIGHTS WITH HID'S - AMP POWER STEPS (the best) - AMP BED STEP - PIONEER Z110BT NAVIGATION - BACK-UP CAMERA - A5 ROOF MOUNT SAT W/AUTO TRACKING - 12" FLIP DOWN DVD - PLAYSTATION 2 - PUNCH 45 - PUNCH 150 - MTX10" THUNDERFORM SUB (now JL sub) - PYTHON AUTO START ALARM - SMARTSTART(for iphone control & notifications of alarms) - K5 TRAIN HORNS WITH 200psi DUAL COMPRESSORS(tied into alarm) ><))))*> Fish On
I signed up for photobucket and uploaded my photos there. Then just copy the URL into a post.
thank you for the info
wow!!! kind of pain but i think i finally got it and also figured out this site a little in the process.
thanks again for the info
1. Post the photo on the web. Your photos in the gallery on TheDieselStop meets that requirement.
2. Look at the photo. Click on the photo to enlarge it to normal size. Right-click on the photo and a pop-up window will open. Scroll down in that window and click on "properties"
3. In the properties window, hilite the URL with the mouse, then right-click the hilited URL and copy it to RAM. Note the URL ends in .jpg, a photo format.
4. Paste the URL into your post. Then enclose the URL in the image operand, which looks like the following except without the spaces:
[ img ] URL goes here [/ img ]
Using one of the photos in your gallery, here's what the code and URL looks like with added spaces so it will show the code instead of the photo:
Without those added spaces, you cannot see the code but instead you will see the photo. Like this:
What is "it"? I'm not very familiar with the VBulletin software used by TheDieselStop, so I though maybe "it" was some sort of posting aid. But I can't find any sort of posting aid that helps you add images to your post, so I don't know what "it" is.
I explained the manual method of posting an image. If there's an easier method, I'm all ears.
Ok, maybe I see the error of my ways. I need to add the .jpg. Here goes:
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
I see you posted a number of pictures in the Photo posting area all you have to do is pull up the picture you want then right mouse on the image and select properties. Copy the URL shown in the properties window for that image.
Then as you are writing a post, select "Insert Image" from the menu icon above the text box where you are typing and it will display a window asking for you to "Please enter the URL of your image:". Then click on OK. Finish your post and then click on "Submit Reply"
Dick
__________________ TheDieselStop.Com Moderator & Photo Editor
May '02 F-350 7.3L SC Lariat 4x4 Auto SRW LWB, Currently 2/2012 - 266K+ miles
June '97 F-350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, Currently 2/2012 - >183K+ miles
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
I swear I tried that, but maybe I used a different properties that had number for the photo ID. Well, this looks like it works.
But, why is the picture so small? Oh, I clicked on the avatar, I didn't open the picture first.
Try again:
I guess that works better.
Mike
You copied the url of the page you were looking at, instead of the url in the properties window of that photo. Here's the URL you used, with addes space so it won't be converted by the editor:
http ://photos.thedieselstop.com/showphoto.php/photo/36975
Here's the correct URL from the properties popup, but with an added sspace so the URL won't turn into a clickable link
