Originally Posted by ffstreetdoc
What will happen if i put a 4 pos chip in a PCM different than the one it was programmed for?? IE chip programmed for PMT1, i have NVK4
You will be fine as long as the chip is burned for the same mods you have.(I.E.- if you have a stock truck and its is burned for an aftermarket trans you will not like the shifting and it could cause issues with your stock trans. Or if it is burned for stock injectors and you have bigger ones) Best call who you got it from and see what's on it first.
