Do I need a re-burn??
Hey There,
Got an F5 from you back in December with stock,80econo, 40,60,80 tows.
Since then I've added an ATS intercooler to try and get the temps down some. Is there anything that Jodie may need to change because of the IC?
Also, thinking of beefing up the transmission for towing. Any changes needed after that change?
Thanks!!
NEW TRUCK: 2002 F350 CC,Short Bed, Dually w/ 7.3L, Air Raid intake, 3 gauge pod w/ISSPRO V2 gauges, Overhead gauge mount with DP Tuner gauge switch, DP F6 tuner w/stock, 1300 hi idle, 80 econo, 120 race, 40 & 80 tow and decel tunes. 4" turbo back Magnaflow exhaust.
http://community.webshots.com/album/576806969VrqaZx
OLD TRUCK:97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
