Other than a DP-TUNER, my 7.3 is completely stock from the paper air filters to the factory muffler. I rented the Dyno at NexGen in Hayward, CA for an hour and ran through all of my 8 settings twice giving 2 minute idling breaks in between. I was stunned. In my 80-tow high altitude, at the wheels my van gained 190 lb/ft of torque and 105 hp! These chips are absolutely unbelievable. I can't wait to dyno it again with my 4" exhaust and intake in a few weeks.
Can you post your stock numbers, and the numbers with each of the tunes? I'd love to see the gains.
Oh I guess so.
Stock:
325lb/ft
175hp
20tow:
415lb/ft
225hp
60tow-alt:
475lb/ft
250hp
80tow-alt:
515lb/ft
280hp
80econo:
470lb/ft
265hp
120race:
500lb/ft
280hp
These are very close estimates within only 3 units of error simply because I had to eyeball the dyno chart. I'm running a Mac and the dyno software you need to view the files only supports PC; I had to use my brothers computer to see them. I know somewhere within the files there is a way to view max HP and Torque achieved but I'll have to fiddle around with it more later.
The owner of the shop explained to me that these numbers are lower than the actual output since there was no load on the dyno and a load is exactly what a turbo engine needs to build boost. I believe he said that load was an option but, it'd take a while to calibrate correctly. This was my first time ever being around a dyno and there were a few things he talked about that I didn't understand such as the different units of measurements like SAE and something else. So long story short, with a time budget of one hour and a bundle of runs ahead of us(2 per setting), I just told him to run the dyno and get some numbers. All the sets of pulls were extremely consistent.
For example with the load, there's a significant difference between 80tow and 120race when driving. 80tow is a jammin setting but, after a second of holding the brakes at a dead stop while giving some throttle to get boost up, I can't even get my van to hook up in the 120 setting! It just smokes the tires! And remember Jody calibrated this chip for an aftermarket 4" intake and exhaust. You can only imagine what his chip will do once I meet my requirements in the next few weeks and ditch the paper air filters, intake resonator and the choked exhaust.
Hi everyone. I am a nuub to the forum, but not to diesel's. I am glad to see that I am not the only one who thinks the E350 7.3 needs more power. I want to purchase this same tuner, but with the 6th setting as the 140hp. Without a larger downpipe, exhaust, and intake could this potentially be dangerous to my engine, and the turbo. I use the van to tow about 8500 pounds of equipment sometimes up to 12000. Its a bit much but the 7.3 is a champ. I like to play as well. That is also part of the reason why I want to upgrade from the stock underpowered tune. If anyone feels that I am hijacking this thread I am sorry. Just want to know if this tuner is too good to be true.
sounds like a winner to me i have been looking in to tuners for about a year now and that is what i was waiting for my fear was buying one and not getting the results that i wont my trucks stock for the mos part but it needs to be able to 12k when it called apon so i have a lot of mods to do but i am taking my time with this build and not rushing in to it thanks for the numbers my first thought is you are makeing more power than you might think with what wrote down ford claims diesel tuner claims 250hp/500 at but didnt say on the motor or at the wheels but if they are correct then your numbers under load would be
20tow 300hp/590tq
60tow 325hp/650tq
80tow 355hp/690tq
120race 355hp/675tq
now one thing you need to know is this a diesel enginesp in doubled in ist tq ie. 5 hp means 10tq you numbers with no load dont reflect this and if what i read is correct then i cant wait to see you numbers after the new mods good luck and i hope i am right
07 raptor 350 jetted and gears pipe (wifes)
03 F150 4x4 5.4 banks stage II 3" exhast (wife's)
03 KTM 250sx scary fast to much to list (mine)
02 F250 4x4 7.3 mostly stock 35's (mine)
02 R6 600cc jetted custom exhust and gears (mine)
00 Z3 2.3 dinen intake and chip (wifes)
87 Quadzilla 500cc scary fast stock (mine)
79 chevy 5.7 425rwhp (mine)
damn keyboard mouse
sounds like a winner to me i have been looking in to tuners for about a year now and that is what i was waiting for. my fear was buying one and not getting the results that i wonted my trucks stock for the most part but it needs to be able to 12k when it called apon. so i have a lot of mods to do but i am taking my time with this build and not rushing in to it thanks for the numbers my first thought is you are making more power than you might think with what you wrote down diesel tuner claims 250hp/500 but didnt say on the motor or at the wheels but if they are correct then your numbers under load would be
20tow 300hp/590tq
60tow 325hp/650tq
80tow 355hp/690tq
120race 355hp/675tq
now one thing you need to know is this a diesel engineis hp is doubled in is tq ie. 5 hp means 10ft of tq your numbers with no load dont reflect this and if what i read is correct then i cant wait to see you numbers after the new mods good luck and i hope i am right
I wanna make a few dyno runs now! I can get 3 pulls for 75 bucks. Wish I could try each tune twice like you did. Guess I might try my 80t, 140, and 100
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff -bullydog egt, autometer boost -f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!) -ats housing/banks big head Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
77ish chevy 1500 w/350 bored .30, torqer cam, some sort of intake man, hi perf elec. ignition, elec. fuel pump & fan, headers & single chamber flowmasters, kc lights, 9" lift, 40" tsl boggers, yukon lockers front & rear, dana 60 rearend, 3sp w/granny gear
ONE BAD MUDDER
Hey Diane, Whats the difference between the high altitude tunes and the normal ones?
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
