04-30-2008, 10:42 AM
#1 (permalink )
smoke
does the 120 setting produce any smoke?
04-30-2008, 10:53 AM
#2 (permalink )
Does what 120 setting have smoke?
2000 F-350 PSD SRW - 8" BDS Suspension, Bilsteins all around, 40/13.50R20 Procomp Xtreme A/Ts, 20x10 BMF NovaKanes, Warn bumper with 15,000lb warn winch, swamps single shot f* mes, H2E turbo, wipeout headstuds, 3.5" H2E Downpipe to 4"-5" exhaust then to some 6" BLACK mitre cuts, Boost-Pyro-Trans-Oil pressure gauges, regulated return, modded idm, DP-Tuner 6 position chip
, Yukon 4.30 gears front and rear, Homemade Traction Bars, Dieselsites billet thermostat housing with 203 degree thermostat.
http://www.rpmoffroad.com
05-01-2008, 10:35 AM
#3 (permalink )
does the 120 hp setting on the DP tuner make the truck blow black smoke from the exhaust?
05-05-2008, 09:36 PM
#4 (permalink )
Mine does but not enough for my taste. I am going to add some programs and the smoke will be one of them.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 9000 miles + on WMO and ZERO problems.
Sitting in the garage but not installed yet.
Banks wheel, HPOP line cross over, 92 gal auxilary tank.
05-06-2008, 12:07 PM
#5 (permalink )
im wonder also anyone got a vid of some good 120R setting runs......
Mikey
1999(10/25/98 Kentucky Plant) F-250 7.3....Stock I Swear
"When In Doubt,When In Fear,Just Drop A Gear, And Disapear"
05-29-2008, 01:34 PM
#6 (permalink )
yes it does!
Mikey
06-02-2008, 10:00 AM
#7 (permalink )
It smokes pretty good in the 120R....but the 140X setting creates nighttime behind me.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Front Bull Bar w/ K.C. Daylighters * Draw Tite Fold Over Gooseneck * Gauges whited out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics *
Sitting in garage waiting to install: 6.0 IC
The REAL toy....
http://community.webshots.com/album/561972003NGydsT
06-03-2008, 10:37 AM
#8 (permalink )
Originally Posted by
fxdwgi
Mikey
06-04-2008, 11:27 AM
#9 (permalink )
mine smokes pretty good and I'm running 100% biodiesel. Its enough to fill a honda civic when you whop them off the line!!!!!!!
06-04-2008, 11:28 AM
#10 (permalink )
what kind of boost numbers do you guys see in the 120R setting? Running empty I can get about 28-29 pounds out of mine and it SCREAMS!!! I have 4" exhaust and the Tymar intake... other than the chip its bone stock.
06-06-2008, 08:38 AM
#11 (permalink )
larecar84
On the 140 setting the truck will dump black smoke on low end and of course it get thinner the faster you go.
99(12/98) F250 Lariat SD PS, 4x4, 8"Sky Jacker lift with 3" hangers,05 Front End Conversion, autometer gauges, 24" KMC Rims with 38" Kumho M/T tires, DP PCM, DP F5 Tuner, 5" Turbo Back Stack Kit With 7" Mitre Cut Tips, Sun Coast Tranny, 513 gears, AMS boost controller, AMS turbo timer.
Linear Mode
» Site Navigation
» Other Sites
» Network Links
