04-30-2008, 10:42 AM
#1 (permalink )
smoke
does the 120 setting produce any smoke?
04-30-2008, 10:53 AM
#2 (permalink )
Does what 120 setting have smoke?
2000 F-350 PSD SRW - 8" BDS Suspension, Bilsteins all around, 40/13.50R20 Procomp Xtreme A/Ts, 20x10 BMF NovaKanes, Warn bumper with 15,000lb warn winch, swamps single shot f* mes, H2E turbo, wipeout headstuds, 3.5" H2E Downpipe to 4"-5" exhaust then to some 6" BLACK mitre cuts, Boost-Pyro-Trans-Oil pressure gauges, regulated return, modded idm, DP-Tuner 6 position chip
, Yukon 4.30 gears front and rear, Homemade Traction Bars, Dieselsites billet thermostat housing with 203 degree thermostat.
http://www.rpmoffroad.com
05-01-2008, 10:35 AM
#3 (permalink )
does the 120 hp setting on the DP tuner make the truck blow black smoke from the exhaust?
05-05-2008, 09:36 PM
#4 (permalink )
Mine does but not enough for my taste. I am going to add some programs and the smoke will be one of them.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. BRV+, CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 12000 miles + on WMO and ZERO problems.
Huge make over on the way.
6.5 Procomp lift, 20" Motos wraped with 37x12.5 Procomp Rubber.
Soon to follow. Ranch hand bumpers, GT38R turbo, High performance HPOP, Head studs, 6" miter cut stacks.
05-06-2008, 12:07 PM
#5 (permalink )
im wonder also anyone got a vid of some good 120R setting runs......
Mikey
1999(10/25/98 Kentucky Plant) F-250 7.3....Stock I Swear
"When In Doubt,When In Fear,Just Drop A Gear, And Disapear"
05-29-2008, 01:34 PM
#6 (permalink )
yes it does!
Mikey
06-02-2008, 10:00 AM
#7 (permalink )
It smokes pretty good in the 120R....but the 140X setting creates nighttime behind me.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
06-03-2008, 10:37 AM
#8 (permalink )
Originally Posted by
fxdwgi
Mikey
06-04-2008, 11:27 AM
#9 (permalink )
mine smokes pretty good and I'm running 100% biodiesel. Its enough to fill a honda civic when you whop them off the line!!!!!!!
06-04-2008, 11:28 AM
#10 (permalink )
what kind of boost numbers do you guys see in the 120R setting? Running empty I can get about 28-29 pounds out of mine and it SCREAMS!!! I have 4" exhaust and the Tymar intake... other than the chip its bone stock.
06-06-2008, 08:38 AM
#11 (permalink )
larecar84
On the 140 setting the truck will dump black smoke on low end and of course it get thinner the faster you go.
99(12/98) F250 Lariat SD PS, 4x4, 8"Sky Jacker lift with 3" hangers,05 Front End Conversion, autometer gauges, 24" KMC Rims with 38" Kumho M/T tires, DP PCM, DP F5 Tuner, 5" Turbo Back Stack Kit With 7" Mitre Cut Tips, Sun Coast Tranny, 513 gears, AMS boost controller, AMS turbo timer.
Linear Mode
» Site Navigation
» Other Sites
» Buyers Guide
» Network Links
