Never mind 10mm and they are nuts. Very difficult to install. I have the 1.0 exh. housing and on the excursion the rear a/c lines have to be unhooked from there original mounts otherwise the T Master will bind up on the steel lines, as it is will barely clear the firewall. Still haven't been able to put the e-clip on. Only solution I see is to pull the turbo.Trucks may be less difficult since they don't have rear a/c and heat. The BDP 1.0 Exh Housing could be the problem also.
01' X PSD 124,000..... ais filter..ccv mod..complete turbo rebuild...new boots...BDP 1.0 ex housing...wicked wheel....turbomaster waste gate controller...boost relief valve....stock exhaust BTM...valve body upgrade...TC Lockup...DP Tuner stock,60 tow, 80 econo....KCM SS HPX Line..Autometer gauges...Skyjacker Hydro Shocks...KYB Steering Stabilizer....Roadmaster Rear Suspension System... Redhead Steering Gear Box....BFG 285/75/16...Weld Wheels.
Reason: more info
