Very quick service
I placed an order for the high pressure crossover line, custom mounting bracket that I will be using for a amsoil duel bypass, and a billet thermostat housing at 11:08 am, and at 11:26 am I recieved a product has shipped email. That is fricken amazing, less than 20 mins. later the product is on its way. I've gotta give you a double thumbs up  for that. You sell great products with great service. Keep up the good work!
2000 Ford F350 4X4, SRW, SB, Auto,Crew Cab, White with custom 1969 ford burnt orange stripe in center, 2005 grill conversion, DP Tuner F5, Kenwood 7120, Fumoto Valve, CCV MOD, AFE stageII PG7, Walker BTM, Custom inbed toolbox w/ Binkley inverted 5th wheel mount, Zoodad Mod, Rough Country dual steering stabilizer, Rough Country shocks, Tuff Country leveling kit, aih delete, Sonnex/Tricum. kit, Bulldog remote start, Wicked wheel, A/C valve mod, TC lockup mod, Superlift truspeed, DIY coolant filter, Zerex Gold ELC, Royal Purple fluids all around, 2008 rear diff cover, Autometer guages w/ 3 guage piller pod, Air-lift airbags with 2 guage compressor, Truxport soft tonneau cover, FPR mod to 72 psi., Drilled and slotted rotors with Hawk pads, 10 x 16 Weld Stonecrusher with 315/75/16 Toyos, Centramatic balancers, Daily driver used to pull a Ditch Witch 7610 trencher around on a gooseneck trailer. Total weight for truck, trailer, and trencher 28156 lbs. Go Steelers
