Looks good, ive got a set of 6" plain mitre cut stacks on order to do the same thing but i thought about teflon coating them instead of using high temp paint. How well do you think the paint will hold up? I had chrome but i like the black look alot better and the dull flat black is about the only way to go. Looks sharp.
2000 F-350 PSD SRW - 8" BDS Suspension, Bilsteins all around, 40/13.50R20 Procomp Xtreme A/Ts, 20x10 BMF NovaKanes, Warn bumper with 15,000lb warn winch, swamps single shot f* mes, H2E turbo, wipeout headstuds, 3.5" H2E Downpipe to 4"-5" exhaust then to some 6" BLACK mitre cuts, Boost-Pyro-Trans-Oil pressure gauges, regulated return, modded idm, DP-Tuner 6 position chip , Yukon 4.30 gears front and rear, Homemade Traction Bars, Dieselsites billet thermostat housing with 203 degree thermostat.
so far so good on the paint.. its a silica/ ceramic base paint that cures while you drive it... or you can put them in an oven to bake the paint on it....
Originally Posted by mk3drift
do you have the Y in the bed?
yup i do...didnt paint that because ill be building like a cage around it using 1"square tubing and some diamond plate so that when i need to load up my quad i can put the front tires over it without worrying about messing up the Y pipe
dude raul good call on spraying them black. when you gonna get some tow mirrors! lol
lol i know i know...very soon bud... cant decide on either dual Fox Res shocks, bushwacker flares, or tow mirrors for my next mod.... i want to get something before the bakersfield event in 2 weeks we will see
