Tsb 05-20-03 - Oil Pan Corrosion - 7.3l Or 6.0l
1999-2006 F-super Duty/e-series, 2000-2005 Excursion, 2000-2006 F-650/750 - Oil Pan Corrosion - 7.3l Or 6.0l
Some Vehicles Equipped With The 7.3l Or 6.0l Diesel Engine May Exhibit Engine Oil Pan Corrosion When Operated In High Salt Content/corrosive Environments. If The Customer Is Concerned With This Cosmetic Issue, The Following Procedure May Be Used To Resolve The Condition. Inspect The Oil Pan. If Corrosion Is Detected Use Motorcraft High Temp Anti-corrosion Coating, Part Number Pm-13-a, To Service.
