4"x30' 40,000# recovery strap enough? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > Off-Road Discussions
Off-Road Discussions Off-Road, modifications and racing forum. This is for Off-Road racing only, The Diesel Stop does not promote speeding or racing on the street and does not promote tampering with ANY EPA pollution devices for street driven cars or trucks!
Old 11-09-2009, 12:06 AM   #1 (permalink)
im looking at one of these on ebay and it has a 40,000# breaking strength. is this enough to snatch and pull stuck vehicles without worrying about it breaking? i already have chain marks in the tailgate of my truck from this past weekend, and i dont want anymore.
early 1999, 7/98, F-250 7.3L, 250,000+ miles, 4x4, triple disk torque convertor, AFE dryflo home made cold air intake, straight pipe exhaust, superchips tuner (stuck on high performance tune,because someone stole the tuner out of my truck), 4.7K mod, Glow shift gauges (pyro, boost, egt), CCV mod, 3in of lift in front, 1in in back w/ 2009 SD rims w/ 2in wheel spacers wrapped in 325/65/18 Fierce Attitude MT, aftermarket headlamps w/ LED's, ranchhand grill guard, 03' front bumper w/ fog lights, gooseneck hitch
browningbuck225 is offline
Old 11-09-2009, 01:06 AM   #2 (permalink)
95DRW4x4's Avatar
It's best to have a recovery strap that will strech and one that doesn't have hooks on it. In many off road recoveries the pulling vehicle needs to be moving and the strap absorbs that energy , like a rubberband, and jerks the stuck vehice out. Chains and cables don't allow for this type recovery and that's why parts get broken and bent! Hooks on straps often become missiles and can go thru windshields. It's best to have "D" rings or some other type of secured fastener. Most stretch type recovery straps have loops on the end that can be secured on the vehicles tow hooks/points. A 4 inch strap at 40K is pretty hefty! I've used 2 inch 20K for pulling my Ranger (5K) for 16 years and it's never broken. I've even recovered full size K5s and F-series truck with it. Maybe a 3 inch 30K might be best for a heavy truck. You just want it to be able to strech a little otherwise you could use a chain!
95 F350, 7.3 PSD, CC, ZF5 speed, 4x4, Dually, Autometer EGT, Boost and Engine Temp Gauges, DP and 4 inch exhaust, Tymar Intake, CPR Fuel System, Adrenaline HPOP
85 Ranger, 302, ZF5 speed, Klune-V, Dana 20, Explorer front and rear diffs, 35 inch TSLs, ARBs, Superwinch
95DRW4x4 is offline
Old 11-09-2009, 01:33 AM   #3 (permalink)
Matt0987's Avatar
Having never considered this.... Are there elasticity ratings on these straps that we should be aware of ? Or, anything else ?
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-09-2009, 01:35 AM   #4 (permalink)
Matt0987's Avatar
What about length? I have to guess they come in different lengths, right? Or, are they all a standard (1) length?
Matt0987 is offline
Old 11-09-2009, 08:45 AM   #5 (permalink)
95DRW4x4's Avatar
Yes they come in different lengths. I've seen them in 20 and 30 foot lengths. As for elasticity, the higher the rating the less stretch your going to have on a lighter vehicle. If you go to pull a Smart car out of a ditch the 4 inch strap probably won't give much. The strech is not a lot just enough to prevent that sudden impact you get from a chain.
95DRW4x4 is offline
Old 11-09-2009, 08:57 AM   #6 (permalink)
yea the chain is not a good thing, i learned that this weekend the hard way, now there are dents running up my tailgate. I think im gonna get the 4"x30' which should definitely be plenty of snatching strength
Old 11-09-2009, 09:57 AM   #7 (permalink)
fireguywtc's Avatar
I am not sure of this, but the strech is not significant on this kind of material but a lot more forgiving then chains. IIRC these types of straps and such are rated with a 2to1 safety factor on the towing rating. However, if it says breaking strenght, that is what it is.
07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe
67 F-250 Project truck, currently in a billion pieces
70 F-250 4x4 (highboy)
Past trucks: 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
fireguywtc is offline
Old 11-19-2009, 05:54 PM   #8 (permalink)
I carry 3 straps in my ~26000 lb Unimog camper. A 2" Masterpull kinetic rope(131K breaking strength) for bigger trucks than me; a 40mm Marlow kinetic rope (66K) for trucks my size and somewhat smaller; and a 1-1/8" (~33K) rope made up by a rigging shop for pickup sized vehicles.
If EITHER the puller or the pullee is smaller, the snatch strap can be safely sized for the smaller vehicle. Think about the boundary condition of either vehicle being infinitely heavy; the limiting factor is the weight of the lighter vehicle and its' effective coefficient of friction ("stuck factor", which can be up to 3 for deep mud).
I also carry 3 X 1-1/4" Crosby shackles primarily to rig the 2" rope. They have a safe working load of 12 tons and breaking strength of 144K lb, > than the rope. They also weigh 9.5 lb each.
Charlie
diesel Landcruiser & M37; 05 Unimog U500 w/Unicat camper
Charlie is offline
Old 11-20-2009, 12:07 AM   #9 (permalink)
Im using the ARB snatch strap (ARB715) and its pulled a few framed super duties out of the thick south Florida mud. I also use D ring receiver hitches and that setup hasent failed me yet***
Tow/Recovery Straps
2006 CC F250 FX4, SCT X3 with custom tunes, MBRP 4" turbo back, EDGE Insight w/ EGT probe, s&b...
choff12 is offline
Old 12-20-2009, 02:58 PM   #10 (permalink)
NEVERSWEAT7's Avatar
I have different length and different rated straps for my rigs. The jeep is 20K the 350 was 30K , 450 is 40K I try to keep as close to as possible a 4 to 1 safety rating. Most likely will never get to 2/3 of rated pull but it is a just in case or better yet, a case by case scenario.
I have been working in the recovery business with my rigs for 35 years and also agree no two hooks. I use clevis pins ( shakle brakets/d rings) secured to woven in eyesplices found in ARB and Warn products to secure the set up. It is true acceleration will telegraph pull force to object stuck but you do not want so much line out to attain such a speed that will seperate tow components from their structural anchors.
I also use winches with at least 3 to 1 MAs to ease the object from its earthen grip. Nice slow smooth action that way. The strap is a little more dynamic.
2010 F-450 King Ranch (loaded)
Alpenlite Portofino RL36
Reese 24K Sig Series fifthwheel hitch
Reese 30K Sig Series gooseneck hitch
Aerotank 65 gallon tool/tank box ( on timer)
Eclipse AVN726E Nav
NEVERSWEAT7 is offline
Old 12-20-2009, 06:26 PM   #11 (permalink)
BubbaZ71Tahoe's Avatar
Hey man.. me and my buddies have popped a bunch of straps.. my heavy tahoe has popped a 4inch and a couple 3 inch straps..
After having popped a bunch my buddy went to Shannon Hardware in Lafayette and bought 100ft of like 2inch tugboat rope... We braided loops to the ends for shackles and have been using it ever since... I highly suggest it.... it streches like a rubber band!
2002 f250 ecsb 7.3,4r100 triple disc converter shift kit, amsoil atf, 60/10.5 DIY Tymar, (ISSPROboost, trans, Egt) PHP FU.
AutoEnginuity in the Lafayette-Houma area
BubbaZ71Tahoe is offline
Old 12-20-2009, 09:12 PM   #12 (permalink)
Matt0987's Avatar
Is this the same company???
www.shannonhardware.com
Matt0987 is offline
Old 12-20-2009, 09:54 PM   #13 (permalink)
yea thats the hardware store...
Old 12-23-2009, 01:37 PM   #14 (permalink)
I understand popping but you have to hit it fairly hard to get that action. That is unless you have collected some faulty straps. I have never done it but who knows.. maybe I was lucky in the order.
I used to have a piece of elastic rope designed for pulling big electric wire through conduit. It was some of the most awesome elasticity on the planet. I would love to get another chunk of it and keep around.
Eclipse AVN726E Nav
Old 01-01-2010, 04:30 PM   #15 (permalink)
Tow/Recovery Straps
Snapped one of those clean in half with only a 1/2 F-150. I'll never use the cheap crap again. I've upgraded twice. I went to this TSC 6" 55K strap. Almost broke that and have since got a Master pull 74K lb recovery strap With the master pull you'll pull out a tow point or two (pulled one out of a F-550 with the master pull), the strap was still fine.
There is a place in Tampa, FL called Certified Slings that will also make similar straps. I know that the master pull is pricey but all you have to do is break a strap once to be at a 500 dollar deductible or worse really hurt or KILL someone
MonteCarlo31 is offline
