Diesel Forum - TheDieselStop.com - View Single Post - transmission rebuild question
post #7 of (permalink) Old 12-07-2006, 02:58 PM
faster67
Re: transmission rebuild question
The Suncoast kit is a good one. Just make sure you get a good TC to go with it, as a stock TC is junk.
I disagree. The Suncoast kit is repackaged Alto's plus a soft kit. You can save a bunch buying the Alto stuff seperately, if that's the way you decide to go with your build.
As far as converters go, you don't have to buy a triple disk unless you plan on making some power. If you do plan on making some power down the road, Precision wins hands down. They're $1050 straight from Precision, which is a few hundred cheaper than the other "good" converters from the big names. There's even people who will build you a converter for half of that.
Billet input shaft for a nearly stock longblock? If it's for the '01 you're limited by the PM rods. Unless the longblock is going to be upgraded in a big way a stock input shaft works fine, or you can spring the $65 for 5R110 input shaft that drops right in. I used the 5R110 shaft in mine, but my original input shaft was still perfect.
If the build is headed towards the 500+RWHP mark then there's some areas of the transmission that should be addressed after the engine internals are upgraded.
faster67 is offline
