Diesel Forum - TheDieselStop.com - View Single Post - dead links (question inside)
post #3 of (permalink) Old 01-04-2004, 04:02 PM
Larry M
My Photos: (11)
Retriving broken/dead links
For all those having issues with finding broken links to the archived section of the site there is a utility that will find these <font color="red"> HERE</font>. What you have to do is type in the Thread ID # (not a post #) and it will return a link to that Thread ID. You can get the Thread ID number by either clicking on the broken link directly and finding the Thread ID in the address bar or right clicking on the broken link and finding it under the properties. The former is probably best since you will already be there when you discover the link is bad. Only hiccup that might exist is when a link is done to a certain post within a thread using the "threaded mode", I don't think that the number in the link for the Post # in that thread will work with the utility will work for Post #, just Thread IDs so make sure you use the Thread ID to be safe.
This utility might not be a permanent feature or be incorporated in some other way and if that happens I'll try and update the status of this utility here.
Larry
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font>
, BTS w/Schaeffer's ATF
, ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10 Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
, & a 1981 26' Prowler TT(26Y)
Larry M is offline
