Diesel Forum - TheDieselStop.com - View Single Post - What I've learned about the E4OD
post #6 of (permalink) Old 10-25-2009, 09:08 PM
Mark Kovalsky
Mark Kovalsky's Avatar
My Photos: (6)
Originally Posted by M.L.S.C. View Post
The coast clutch is also applied by the PCM when the trans goes into OD.
The coast clutch is NOT applied in overdrive. If it were on there would be a tie up, which is when all parts of the planetary gearset are held to the case. That means that the output shaft would immediately stop turning, which means the wheels would stop turning. There is engine braking in overdrive without the coast clutch applied.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is online now
