Diesel Forum - TheDieselStop.com - View Single Post - axle gearing and towing up hills
post #7 of (permalink) Old 11-14-2011, 09:13 AM Thread Starter
SGT JUNK
SGT JUNK's Avatar
Hey Guys sorry for the delay, no internet in Amish Country, Pa.
I will probably play around with the tire size, as I need to get new tread anyway. I don't have a turbo and don't plan on putting one in, i love the simplicity of it even though the turbo is still really basic.
I figured it would scream with 4.88s I don't really want that much noise, but I will tow for another year or so and see about the gear MOD. FL is very flat. Orlando is about as flat as it gets. so I don't need lower gears, but if there was a worth while benefit to doing gears than I'm interested in it.
1Dieselman
I haven't done much reading on tire size and gear ratio. I seems odd that changing gears and switching tires around didn't cancel each other out, although you did state the benefits of what you gained by doing so. I will think about that a bit more and probably do what you did.
Thanks again guys great info
1992 F-300(F-250 with DRW
) Ext. Cab, LB, Dana 50 4x4, E4OD, 10.25 Sterling All stock work truck. it's ugly but I'm slowly liking it more. Just bought it in Sept.
SGT JUNK is offline
