Diesel Forum - TheDieselStop.com - View Single Post - Offset & Backspace - How Do They Relate?
post #11 of (permalink) Old 01-13-2012, 12:46 AM
Maverick4x4
Maverick4x4's Avatar
My Photos: (5)
Hi Discount!
I won a set of MB rims from Discount, looking at the Gunner 8's in the 18X8.5 8-170 -6C
Using the math above, does that mean they will stick out 1.25" more than the factory 16x7's?
And in another 1/4"?
You said: " In terms of Backspace. A 16x7 +6mm offset has a 4.25" Backspace. A 16x8 -6mm offset also has a 4.25" Back Space." So an 18x8.5 -6mm would have 4.5" of backspace? (8.5/2 = 4.25, then subtract the 6mm =4, then add half of the 1", so 4.5")
This makes me nervous when it comes to running tire chains, there isn't a lot of room between the fenders and the inside of the tires...especially if I run the 325/65r18 size tires that I'm looking at. I'd better chain up the 305's that are currently on there and see how much room I have left.
Thanks,
Brett
'02 PSD X Ltd 4x4 "the new a-burbit" - Noah, 2 1/2. Corrected suspension (V-codes w/addaleaf, Ride-rite's with a Bruce inspired tank, Hellwig Anti-Sway) dvd/vcr, 35's on 18's, Airaid stage 2, Walker BTM, pyro, ported housing, DP 60 special tow, 60high, 80high, 80econo, 100 perf, doo-dads, blah blah blah. Some kind of metallic blue with tan trim.
'81 scrambler...with a various assortment of 1 ton parts.
'90 blazer with a big snow-throwing whirly thing on the front
'90 YJ with lockers and stuff (kids car)
'08 supercrew paid for by work
'13 Subaru for my bride
'77 F-150 with Rainbow stripes reserved for the Relic Run TM
Maverick4x4 is offline
