Diesel Forum - TheDieselStop.com - View Single Post - Help with JIC fitting on RiffRaff HPx ??
post #3 of (permalink) Old 05-30-2013, 10:42 PM Thread Starter
farnorthdriver
Hi Jposes,
I can't say because I haven't removed the plugs yet. I got the fuel regulator off and noticed that the sealing seat on the plunger didn't look too good. My understanding is this seal on the plunger is extremely critical for proper function of the regulator. If it doesn't seal you can have problems with pressure regulation. So ordered a new one and am waiting for it to arrive before finishing the fuel crossover install.
As for getting the plugs out did you read this thread?,
http://www.thedieselstop.com/forums/...x-help-278718/
Do a subject only search on Frx and you'll get more info on it.
1999 F350 DRW Long Bed Crew Cab 4x4
Carries 5000lb+ Lance Camper
DP Tuner chip w/ 60econ, 120race, decel, hi idle
Stancor Glow Plug Relay
VDO gauges
Ford AIS and zoodad mod
MagnaFlow 4" Exhaust and muffler
Bellowed Up Pipes from Int'l
John Wood Eco HD trans, 6.0 cooler and Maghytec tranny pan
Maghytec rear diff cover w/ Mobil 1 75W-140
Mobil 1 ATF in trans/transfer case/powersteering Magnafine filters for tranny and power steering
Airbags, KYB Monomax shocks, Torklift Swaystops, Roadmaster 1.5" Rear Sway Bar
CCV mod
TransferFlow 57 gallon fuel tank
Riffraff fuel and oil crossover
Strictly Diesel fuel tank/pre-pump kit
Air intake heater delete Max A/C assist Braided 4WD shift hoses, Replacement boots for all turbo/intercooler boots, Coolant filtration system, 203*F thermostat
2 layers Dynamat Extreme on interior roof/floor/doors, Dynamat Xorb on Firewall
Alpine IVA1000 and amp, Python Alarm
farnorthdriver is offline
