Diesel Forum - TheDieselStop.com - View Single Post - Dp Tuner..with 35's and 3.73's
post #2 of (permalink) Old 06-13-2013, 06:43 PM
RT
RT's Avatar
I believe your engine will handle it just fine- I think your issue will be the transmission - did you tell Jody what tire size / gearing combo you will be running? At least he could adjust the shift points.
Sent from AutoGuide.com App
RT is offline
