Diesel Forum - TheDieselStop.com - View Single Post - Installed hybrid injectors, rough idle, codes
post #1 of (permalink) Old 03-14-2005, 06:17 PM Thread Starter
bct222
Installed hybrids this weekend and after the normal test drive to evacuate all the air the truck idles very rough. It lopes and searches around for a smooth idle. Puffs white smoke when pulling out at partial throttle after stopping at a red light. Power is good at speed, EGTs are fine, oil pressure good.I pulled the following codes.
Reoccurring codes
P0476- Exhaust pressure control valve performance, I gutted the EBV
P0541- Manifold intake air heater, I removed air heater
New codes
P1293- High side open-bank 1 Right
P1294- High side open-bank 2 Left
P0603- Internal control module KAM error, Battery was disconnected during swap
P0606- PCM processor fault, Battery was disconnected during swap
P1670- EF feed back signal not detected ?
An HX cross over hose was installed and the fuel pressure regulator was shimmed to 72psi at the same time.
Any ideas?
bct222 is offline
