Diesel Forum - TheDieselStop.com - View Single Post - Stripped Dana 50 4WD spindle, need replacement advice
post #16 of (permalink) Old 02-02-2014, 10:01 AM
Stan96
Stan96's Avatar
if you look on rockauto you'll see both of the moog seals, the 14 is called the inner and the 13 is called the outer, i used the 13 between the axle yoke and the back of the spindle, i don't remember any other parts between the axle yoke and the back of the spindle besides the 13, also don't remember using the 14 at all, the d60 might be different and it's been a while so i can't really be certain
1996 F-350 XLT 4x4, e4od, Electronic-rustproofing, Viper alarm
2004, @32k mi. glowplugs, drag-link, Michlelin's, waterpump
2010, @76k mi. Ball joints, u-joints, rotors
2011, @86k mi. glowplugs, drag-link, trany fluid
2012, @94k mi. Bilsteins, stainless brakelines, fuelbowl, lift pump, waterpump, steering lines, coolant filter
2012, @98k mi. Starter, positive cables, batteries
2013, @104kmi 3"downpipe, Michlelin's, steering damper, rotors, rear diff oil
2014, @115kmi. Injector o-rings, alternator rebuild
Stan96 is offline
