Diesel Forum - TheDieselStop.com - View Single Post - Barder's 360 bearing rebuild,XDP billet,Applied Performance
post #3 of (permalink) Old 07-14-2014, 08:22 PM Thread Starter
Maryland dieselnick
One the housing has had the rust removed and seal groove cleaned out take the larger of the two seals out of kit and install on exhaust turbine end.
They are just like a piston ring they will expand a little but are brittle and will snap.
You may want to use fingers or you may want to use ring expanding pliers.
Maryland dieselnick is offline
