Diesel Forum - TheDieselStop.com - View Single Post - 2wd front wheel bearings
post #2 of (permalink) Old 04-15-2005, 06:41 PM
bekair
Location: Vancouver Island during the summer - El Centro (Sunbeam Lakes) in winter
Re: 2wd front wheel bearings
I'm looking forward (NOT) to doing the same thing.
I'm not sure of mileage to do this job - but if you are going to do pads - it would seem to me that this is the ideal time.
Search for removeing calipers do that then remove hub (unscrew hub nut) after removing cotter pin - pull off hub - when hub is lying on ground (or whatever) carefully punch out inner seal, lower bearing should fall out, clean old grease - regrease with factory spec. (I'm going to use syn.)
Instal brgs. TAP IN NEW SEAL VEWY,VEWY CAREFULY - instal on spindal - hook up caliper.
pay attention to wheel hub tightness - install cotter pin (new)
Sounds so gosh darn simple !!!!
Am I missing anything?
OOOHHH - BTW - order ALL PARTS you think you need from Dale - @
www.powerstrokeshop.com
Barry
2000 F350 XLT Crewcab Longbox SRW. Born 04/2000
in service 05/2000.(BIGBLUTHUNDR)
all mods by John Wood
c/w John Wood ball hat
Monroe gas mags.& Timbrens.
All on Michelin LTX.
It ain't broke, but I'm fixin it 'till IT IS!!
"Wet"7710lbs. pulling 2004 Cougar 295EFS 9900 lbs.
YIKES - my wife can put more clothes in?
Inside - Barry, Margy, & Zeah the wonder dog.
"Too soon ve get olde - und too late shmart".
Ha, Ha, Ha - SoCaps member - go figure?
bekair is offline
