Diesel Forum - TheDieselStop.com - View Single Post - Speedo swap ?
Thread: Speedo swap ?
post #13 of (permalink) Old 05-01-2015, 09:05 PM
Lilnuts
The final step is to cut one tab off the F cluster (sometimes referred to as the F'n cluster if it doesn't work).
The upper left tab has to be cut off the F cluster it cuts easy with a small saw (I used a coping saw)
For a better alignment in the dash I cut a small notch in the van dash, it's only about a 1/4"
2002 7.3 psd stretch window van, 140K Dp tuner F5 7 tunes, 4" turbo back, Wrapped exhaust, bellowed up pipes, Bilstein Hd's, RiffRaff RFX, HPX & CVC & AIH delete, 235/85/16 Michelins, Hid's, Auto-meter tranny temp, boost and pyro gauges, Mag-Hytec deep trans pan, towing mirrors, dynamat doors, Alpine 1000w blaster
I found building 5 mast sail boats inside a mini bottle wasn't challenging enough, so I bought a powerstroke van!
2016 F350 DRW CC long bed 6.7 stroker.
Lilnuts is offline
