Diesel Forum - TheDieselStop.com - View Single Post - Hi, need help hard starting gets worse when it's colder out
post #6 of (permalink) Old 11-15-2015, 06:03 PM Thread Starter
dutyhole
Originally Posted by Maryland dieselnick View Post
Ohm your glow plugs at the valve cover connections. Do a voltage drop on glow plug relay.
Sure, disconnect harness at valve covers. Foreword and back pin is glow plugs. Set meter to read ohms. One lead to glow plug pin, the oth to ground. Look for .2-2.0 ohms.
Activate relay by jumping in the activator small wire. Read voltage on big posts- in and out
ty if the glow plugs are bad what kind is everyone using ? one person did suggest i could have a bad injector ??
dutyhole is offline
