Diesel Forum - TheDieselStop.com - View Single Post - 2017 Ordering
Thread: 2017 Ordering
post #27 of (permalink) Old 01-16-2016, 10:01 AM
FordWilly
FordWilly's Avatar
Originally Posted by VermontWayne View Post
From all I've read on the 2017, both Ford writings and independent writers, the only options with respect to fuel tank size will be dictated by which wheel base version you buy...just as it currently is. What did you read that lead you to believe there would be three different options?
Below is what my friend Bobby Williams (Fleet Director Sunrise Ford Fontana Ca.) posted on the Southern Ca. Powerstrokes Website on the ordering forum last September. Read way down and it mentions new fuel tank options.
  1. Because owners depend on their truck for the most difficult jobs, we made it the toughest Super Duty ever(1), featuring:
    • First-in-class(2) high-strength, military-grade aluminum-alloy truck body and box for improved capability and improved dent- and ding-resistance over the previous generation
    • All-new fully boxed frame, built from 95 percent high-strength steel for a foundation thatís up to 24 times stiffer than the previous generation
    • Together, high-strength steel and high-strength aluminum alloy help reduce weight by up to 350 lbs. Ford is reinvesting this weight savings everywhere it counts to help give customers even more towing and hauling capability than ever before for Super Duty
    • Upgraded driveline and suspension components (axle, transfer case and driveshaft) to manage the increased torque, towing and payload
    • 12 million miles of Built Ford Tough testing so itís designed to meet or exceed our most demanding customersí requirements
    • All-new conventional hitch design allows for improved towing capability(1)
    The Smartest
    Technologies
    The all-new Super Duty Pickup is designed with the latest available technologies, helping owners work harder while marking their work experience easier:
    • Class-exclusive(2) Adaptive Steering
    • Up to seven cameras, including:
      • Class-exclusive(2) 360-degree camera with split-view display
      • Center high-mounted stop lamp (CHMSL) camera
      • Class-exclusive(2) customer-placed trailer camera
      • Class-exclusive(2) Trailer Reverse Guidance
    • SYNC 3
    • Class-exclusive(2) BLIS (Blind Spot Information System) with cross-traffic alert and trailer tow
    • Lane Departure Warning system
    • Class-exclusive(2) adaptive cruise control and collision warning with brake support
    • Class-exclusive(2) inflatable outboard rear safety belts on Crew Cab models
    • Class-exclusive(2) Trailer Tire Pressure Monitoring System
    • Tire Pressure Monitoring System (TPMS) now standard on F-350 DRW models
    Exterior Features
    From the very first look, itís clear this is a truck thatís designed for work with these available features:
    • Larger cabs with new 170-degree doors on SuperCab models
    • Class-exclusive(2) quad-beam LED headlamps with configurable daytime running lamps
    • Class-exclusive(2) LED side-mirror spotlights
    • LED security approach lamps
    • LED box lighting and tailgate LED
    • LED taillamps
    • Class-exclusive(2) remote tailgate release with power lock
    • Class-exclusive(2) next-generation tailgate step
    • Class-exclusive(2) BoxLink with premium locking cleats
    • Class-exclusive(2) power-deployable running boards
    • Extended running boards that offer easier access to the bed
    Interior Conveniences
    New comfort and convenience features put the emphasis on owner satisfaction with:
    • New seat designs with new materials and colors
    • Class-exclusive(2) standard second-row flat load floor with new lockable storage on Crew Cab models
    • Class-exclusive(2) available multicontour front seats with Active Motion
    • Class-exclusive(2) available 110-volt power outlets with a combined maximum output of 400 watts
    • Class-exclusive(2) available inflatable rear safety belts on Crew Cab models
    • New instrument panel with dual glove box and center console with sliding cupholders and expansive storage
    • Intelligent Access with push-button start
    • Ambient interior lighting
    • Enhanced upfitter switches relocated to the overhead console; now includes six switches with more total amps
    • Twin-panel moonroof on Crew Cab models
    Most Capable
    The all-new Super Duty Pickup is designed to be the most capable Super Duty ever, carrying more, towing more and delivering the most combined horsepower and torque(1)
    • The first-in-class(2) high-strength, military-grade aluminum-alloy body and box reduces weight, allowing engineers to strengthen the frame for increased capability
    • Highest-ever 5th-wheel/gooseneck towing, conventional towing and payload capabilities of any Super Duty(1)
    • Increased fuel tank capacities for greater driving range
    Powerful
    Compared to previous Super Duty models, the 2017 powertrains are designed to deliver more combined horsepower and torque than ever before with proven engine and transmission combinations:
    6.7L Power StrokeDiesel V8
    • TorqShift 6-speed automatic transmission
    • B20 biodiesel capable
    6.2L FFV V8 Gas Engine
    • New TorqShift-G 6-speed automatic transmission (F-250)
    • TorqShift 6-speed automatic transmission (F-350)
    • Available dual batteries
    • Available CNG/​Propane Gaseous Engine Prep Package
    The Toughest, Smartest and Most Capable Super Duty Ever.
    • Class-exclusive(1) technical innovations help owners improve and enhance their comfort, productivity and towing confidence
      • Standard Features
        • Flat load floor on SuperCab and Crew Cab models
      • Available Features
        • 110-volt outlets with a combined maximum output of 400 watts
        • 360-degree camera with split-view display
        • Adaptive cruise control and collision warning with brake support
        • Adaptive Steering
        • BLIS (Blind Spot Information System) with cross-traffic alert and trailer tow
        • BoxLink with premium locking cleats
        • Customer-placed trailer camera
        • Inflatable outboard rear safety belts (Crew Cab)
        • LED side-mirror spotlights
        • Multicontour seats with Active Motion
        • Next-generation tailgate step
        • Quad-beam LED headlamps
        • Remote tailgate release with power lock
        • Trailer Reverse Guidance
        • Trailer Tire Pressure Monitoring System
    • First-in-class(1) high-strength, military-grade aluminum-alloy truck body and box
    • Increased towing and payload capacities
    • Powertrains with more combined power and torque
    • Highest-ever 5th-wheel/gooseneck towing, conventional towing and payload capabilities of any Super Duty(2)
    • 12 million miles of Built Ford Tough testing so it's designed to meet or exceed our most demanding customersí requirements
    • Up to seven available cameras, including the class-exclusive(1) 360-degree camera with split-view display
    Bobby Williams
    Director of Fleet Sales
2011 Lariat Long Bed Crew Cab Dually 4X4
FordWilly is offline
