Diesel Forum - TheDieselStop.com - View Single Post - Fuel heater O rings
post #12 of (permalink) Old 04-19-2016, 02:12 PM
Bill1013
Bill1013's Avatar
Originally Posted by Xeonpony View Post
Useless till it gets cold out!
According to Fords manual, the key has to be left on for 5 minutes prior to starting to make the filter heater to heat the fuel enough to be effective, then key OFF then ON to cycle the glow plugs, then start.
Many many have deleted the heater as I've said for the reason the damn things leak and air intrusion.
Your truck, but do as you want.
The PSD's have the heater at the bottom of the fuel bowl, higher wattage, more effective.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
