Diesel Forum - TheDieselStop.com - View Single Post - Edge CS2 sensor question
post #1 of (permalink) Old 05-08-2016, 06:15 PM Thread Starter
acade
acade's Avatar
Who is running the Edge CS2 or CTS2? I am trying to figure out what I need to get with the programmer. There is an EAS kit that comes with an EGT probe for readings that I plan on getting in addition to the unit. However, does the unit already measure boost and fuel pressure also, or will I need to get the additional Edge EAS sensors to read those? I would think the unit would just take the boost reading from the MAP sensor. I've read about a handful of people removing the AIH and putting in a boost sensor. I was planning on going this route, but if the unit already measures boost, then I don't want to get a sensor just to measure boost 6 inches away from where it already is being measured (the sensor and wiring harness are about $350). Any thoughts?
2000 F350 4X4 XLT CCLB SRW 7.3L ZF6
8.5" Pro Comp lift
16x12 M/T Classic IIIs with 38x15.50 Toyo Open Country M/T rubber
Riffraff Diesel 6637 intake, CCV mod, HPX, AIH delete, CAC boots/clamps/plenum inserts
Riffraff Diesel Coolant Filtration System, Billet Thermostat Housing
MBRP 4" SS straight exhaust
LuK clutch kit
Edge CS2 programmer
VIAIR on-board compressor w/Kleinn air horns
Amp Research Power Steps
2016 tailgate conversion
Iron Cross bumpers w/Rigid Dually LEDs
DeeZee tool box
Gooseneck hide-a-hitch
acade is offline
