Diesel Forum - TheDieselStop.com - View Single Post - School me on Greasecar
post #2 of (permalink) Old 07-27-2016, 11:31 PM
yan7gin
yan7gin's Avatar
this is what the fuel system should look like (see pic). now If modification where made to accommodate other type of fuel well I can't answer because I know nothing about bio diesel.
Personally I would reinstall a fuel bowl and use diesel instead of bio. filtering you fuel is a must
Name:	Returnless Fuel System.JPG
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
