Diesel Forum - TheDieselStop.com - View Single Post - 2004 F250 6.0L SuperDuty fuel pressure issues
post #7 of (permalink) Old 10-21-2016, 09:57 PM
bismic
As mentioned above, you might have an issue with the fuel pump pick-up tube in the fuel tank. It is a pain, but you might want to remove it and inspect.
Also, I would inspect the fuel pressure regulator spring/etc.
Mark
bismic is online now
