Diesel Forum - TheDieselStop.com - View Single Post - DEF fault related to EGT sensor fault?
post #4 of (permalink) Old 07-23-2017, 08:48 AM
larrgh
Look up the OBDII code here and see which sensor it is.
Download or open the listing for your truck year.
https://www.motorcraftservice.com/freeresources/obd
Also, check to see if you can find out if your truck is still covered under warranty extension for the EGT sensors. Might need the ECU/PCM calibration updated also for issues related to this problem.
Larry
larrgh is online now
