Diesel Forum - TheDieselStop.com - View Single Post - Tranny Trouble
Thread: Tranny Trouble
post #3 of (permalink) Old 08-29-2017, 11:51 AM
Mark Kovalsky
Mark Kovalsky's Avatar
My Photos: (6)
The P1728 code can only set when in fourth gear. So if you turn off overdrive it will never set.
I can rule out the solenoid from here. The problem you have is common in those years. The apply piston for the torque converter lockup clutch has developed a crack. It leaks pressure which allows the clutch to slip. The PCM sees the slip and sets a code. The crack will leak more the hotter the trans gets as the fluid thins out. The only way to fix this is to replace the torque converter.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
