Diesel Forum - TheDieselStop.com - View Single Post - Trans issue
Thread: Trans issue
post #1 of (permalink) Old 10-16-2017, 09:09 PM Thread Starter
JoeD7.3
JoeD7.3's Avatar
Trans issue
trucks an 04 with 120k i have spd tunes and wasn't having an issue until i installed a ficm tune. As soon as i took off right after loading it i got a terrible 3-5 shift flare. Dropped pan found this clip in the pan , most said it was a parking pawl. i replaced the 3-5 solenoid with the EPC and took for a drive. The truck went into limp mode and threw p0700 and a code about FICM tuning not being compatible. I have access to ford PTS but they don't show p0700 as a code. I was scanning with a snap on solos pro but if i can at work ill try to get the IDS On it. Thanks
95 F-250 3.55s Auto 33s X 12.50s . 3" DP 5 inch , WW2 , PHP Ts 6 , Flatbed. Extended Cab . 6637 ,
Parts replaced Radiator , all 4 balljoints (moog) starter , fuel pump ,Fuel bowl rebuild , Injector orings and cups, Rebuilt trans ,100k mile transfer case ujoints , both rear leaf packs. 274k and counting
JoeD7.3 is offline
