Diesel Forum - TheDieselStop.com - View Single Post - Cold weather starting
post #3 of (permalink) Old 12-25-2017, 11:54 PM
DENNY
If you can get in a heated shop that would be the best thing to do. Get it up to temp add anti jell to the tank and just start it. Even putting a heat lamp on the fuel filter would help a lot if it is out in the cold. I would add anti jell to the tank no mater what.
DENNY
DENNY is offline
